Viper 791xv install
jaurora
Silver - Posts: 429
Posted: January 06, 2005 at 1:46 PM / IP Logged
This is my first time using viper products. I have always used prestige and never had a problem but I wanted to upgrade to something a little better. I was looking over the manual and I have a couple of questions that hopefully someone can help me with.
1) I dont really understand the connection of the WHITE/ blue wire.
2) Of course I had to get a few extras for this alarm as well. I got the window module which seems self explanitory and I think that this gets connected to channel 4 of the system. Please stop me if I am wrong. Also I have the proximity sensor. Now would I connect this to the shock sensor wires so both the shock and proximity sensors are both tied into the same harness?
3) Any other help/tips would be appreaciated. I have plenty of installing experiance and also MECP certified so this is not the issue, I just have never installed a viper before and things are a little different. This is going in place of a prestige APS-786 that I had previously installed on my 2001 dodge ram.
Thanks guys for all your help.
MECP certified (If it really means anything)
Jeremy
mobile1
Silver - Posts: 479
Posted: January 06, 2005 at 10:47 PM / IP Logged
1) white blue = activation input = when it sees ground (double pulse) it will start activate the remote starter
2) yes you would connect the proxy sensor to the shock sensor, in the manual it gives you a wiring diagram i believe
italnpimp59
Silver - Posts: 427
Posted: January 07, 2005 at 1:12 AM / IP Logged
actually you could hook the proximity trigger output wire to the instant trigger input wire of the viper alarm, that way your LED will tell you which zone was triggered so you know if the shock sensor or motion sensor made the alarm go off.  but if you dont care about that and you tie it into the shock sensor harness..diode isolate the trigger wires
Wednesday, November 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
