Viper 791xv install
jaurora
Silver - Posts: 429
Posted: January 06, 2005 at 1:47 PM / IP Logged
This is my first time using viper products. I have always used prestige and never had a problem but I wanted to upgrade to something a little better. I was looking over the manual and I have a couple of questions that hopefully someone can help me with.
1) I dont really understand the connection of the WHITE/ blue wire.
2) Of course I had to get a few extras for this alarm as well. I got the window module which seems self explanitory and I think that this gets connected to channel 4 of the system. Please stop me if I am wrong. Also I have the proximity sensor. Now would I connect this to the shock sensor wires so both the shock and proximity sensors are both tied into the same harness?
3) Any other help/tips would be appreaciated. I have plenty of installing experiance and also MECP certified so this is not the issue, I just have never installed a viper before and things are a little different. This is going in place of a prestige APS-786 that I had previously installed on my 2001 dodge ram.
Thanks guys for all your help.
MECP certified (If it really means anything)
Jeremy
gus1
Gold - Posts: 1,013
Posted: January 06, 2005 at 2:06 PM / IP Logged
1) It can be used as a secondary GWR output, or in pulse/latched mode, can be used to turn something on 10sec after remote start( rear Defrost, for example)
2)Yup... you can use channel 4, or even the trunk output for the window module... any thing that can be set up for validity (on as long as you hold the button) As far as the 508D is concerned, you will notice a loop at one end connecting the green and blue wires, and a loose green wire. Viper has multiplex capability on their sensor inputs, which is nice. You can have 2 sensors coming in on one port, and both will have full capability.... no need to diode isolate sensors from each other. Tie the green and blue together on the 508D, and connect to the loose green in the shock harness. You will be able to turn off each sensor separately from the remote, and each sensor will have it's own separate warn and full trigger responses. Kinda neat.
3) Nothingmuch, really. The only thing I have found annoying with DEI stuff can be playing "hide all these damn boxes" For example: Just did an 04 Trailblazer this morning with keyless. So, I got to hide 1)the brain 2) 555LW 3) 455G 4)The relay pack. PITA, but, that's the only complaint.... pretty minor. Everything else is straight forward on these things.... having a Bitwriter makes programming a breeze, obviously, but the menus aren't too bad to zip through with the valet switch an d the LED.
Have Fun, enjoy the Starter Alarm!
Gus
profuse007
Gold - Posts: 2,015
Posted: January 06, 2005 at 2:13 PM / IP Logged
1)(i think Gus1 is confse w/) the wht/blu on H1, do nothing w/ it
Houston,TX
jaurora
Silver - Posts: 429
Posted: January 06, 2005 at 2:38 PM / IP Logged
Gus,
The blue white wire, does this need to be connected? Does it pulse groung or positive outputs?
Thanks for the fast reply and for clearifing things up for me. This is going to be a saturday job. (Prob. all day)
Once again thankyou
Jeremy
kgerry
Platinum - Posts: 3,455
Posted: January 06, 2005 at 2:50 PM / IP Logged
WHITE/ blue is usually a manual activation input.... as a rule you dont use it....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
gus1
Gold - Posts: 1,013
Posted: January 06, 2005 at 4:01 PM / IP Logged
Cursed dyslexia strikes again..... yup. WHITE/ blueis a negative activation input. Can be used with a 556T for example to start at a given time of day, or a pushbutton switch for that one time the remote decides to lose it's mind, and you want to start the vehicle without a key.
Wow... and it's only Thursday.... crap.
Gus
Silversun
Member - Posts: 6
Posted: January 06, 2005 at 4:24 PM / IP Logged
I installed the 791xv on my 2000 Silverado last week. And you are right Gus with all the wires and the brain and the starter relay where do you to put the stuff at?
I have question about mine. It took me three days because it was my first time installing a Viper. My question is that I get a check engine light on when I use the remote start. Check engine light stays on until I reset the pcm. Also when I take off the transmission is in third gear and will not come out, until I stop and turn the truck off and then restart with the key.
There is a brown wire that I think, it is part of the ignition that I didn't hook up. I hook up the pink and the orange wire but did nothing to the brown wire (which is part of the factory wiring not the Viper). Was I suppose to hook up the brown wire to the Pink/White + wire (second ignition)? Because like I said that if I start the truck just using the key, its shift fine, but use the remote start its stuck in third gear.
Any replys will be helpful because I'm installing another one on my 2002 Tahoe.   Thanks
Silversun
Member - Posts: 6
Posted: January 06, 2005 at 4:25 PM / IP Logged
Silversun
Member - Posts: 6
Posted: January 06, 2005 at 4:27 PM / IP Logged
DohooViper 791xv install -- posted image. Viper 791xv install -- posted image.
gus1
Gold - Posts: 1,013
Posted: January 06, 2005 at 4:50 PM / IP Logged
Pink/white on the high current harness of the 791 HAS to go to the white second ignition wire at the column. Powers up part of the TCM, and a heater element in the tranny (from what I gathered onetime when I was looking at a service manual). Brown second accessory dosen't need to be powered up. The orange first accessory does.
Playing "hide the stuff" is part of the allure of being a DEI installer.... and really ugly, 2 sizes too small, free t-shirts once in awhile Viper 791xv install -- posted image..
Gus
