clutch bypass?
kaptain
Posted: January 07, 2005 at 9:25 PM / IP Logged
Hi all and happy NewYear! I,m doing a remote start in 2002 s-10 and need help with clutch bypass,can anyone help? thanks in advance. K.S.
Lowron
Member - Posts: 23
Posted: January 19, 2005 at 12:15 AM / IP Logged
Not sure but if you look at your clutch pedal way up high, you should see a button of some kind that gets pressed when you push in the clutch. Zip tie this button down. Presto! your clutch pedal is bypassed.
extreme1
Silver - Posts: 1,070
Posted: January 19, 2005 at 12:41 AM / IP Logged
ummm, no that is not the way to do it.
I don't recall but there are two wires that need to be jumped together on the GM clutch swich during crank.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
forbidden
Platinum - Posts: 5,354
Posted: January 19, 2005 at 1:47 PM / IP Logged
That is definitely not the way to do it but a great way to start a vehicle in gear. clutch bypass? -- posted image.
