Diodes needed?
antol11
Member - Posts: 6
Posted: January 08, 2005 at 9:38 AM / IP Logged
Hi,
I am installing 4 DEI 805D motion sensors externally on a vehicle (they each have their own enclosures).  My question is will I need dioes on the trigger outputs?  I have tried to contact DEI but I couldn't get a hold of someone to speak with.  Currently I have them wired up to the aux shock sensor input of a Code Alarm 425 alarm unit without diodes and I am having a problem with faulty triggering.  For example when if you trigger the first stage warning it will immediately trigger a full alarm even though the full alarm was never triggered.
Also is it ok to power all 4 motion sensors fromt that aux shock sensor input?  Or should I power them from a battery wire?
Thanks,
Bogdan
gcorrea
Silver - Posts: 436
Posted: January 12, 2005 at 1:43 AM / IP Logged
any time you are using two or more sensors you have to diode isolate. do you mean the 508D proximity sensor?
gcorrea
jaurora
Silver - Posts: 429
Posted: January 12, 2005 at 7:27 AM / IP Logged
I hope not. 4 508D's is a little overkill!!
MECP certified (If it really means anything)
Jeremy
misterjimbo
Silver - Posts: 535
Posted: January 12, 2005 at 7:39 AM / IP Logged
it has been my experience with 508 d's that if you power them from the shock port that it gets quite a few false alarms. may i make a recommendation? get your power and ground independantly for each sensor. 4 sensors is a bit much dont you think? to each thier own
Jschult3
Copper - Posts: 106
Posted: January 12, 2005 at 4:34 PM / IP Logged
Yeah 4 sensors is a little much and you should always diode any time 2 triggers are involved.
I think DEI even suggets using 1 trigger from that power source only. Don't quote me though.
Always Verify Wire information before Connecting! Just a Darn Good DIY'R
auex
Platinum - Posts: 5,041
Posted: January 12, 2005 at 5:36 PM / IP Logged
You are not supposed to power more then one sensor of the fourpin shock harness plug.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
