CLifford 3.5 on Nissan Sentra SE-R Manual
srusin1
Copper - Posts: 86
Posted: January 08, 2005 at 7:45 PM / IP Logged
 I going to install this alarm on a 2002 Sentra Se-R manual. I have red all the reasons not to install it into a manual but the owner never leaves the car in gear. How would i install this? How do I  bypass the clutch/ Is there a neutral safety switch n this car and how do I use it?
profuse007
Gold - Posts: 2,015
Posted: January 08, 2005 at 8:24 PM / IP Logged
youll most likely to find two diff switch on that clutch pedal......that have 2wire on on each switch. find teh switch thats b4 the clutch pedal, thats the clutch wire.
1 out of the two wires will be ur target wire. its a negative trigger.
i only have heard of NSS on the newer subaru
it sounds like youre using a unit that doesnt handle the MTranny. to be on the safe side, use a unit thats design for it.
Houston,TX
srusin1
Copper - Posts: 86
Posted: January 16, 2005 at 11:23 PM / IP Logged
Anyone know of where the parking brake wire is? I want to hook this up at the very least. Also should i use a relay for the clutch bypass, or could i use the status output. Im confused as to when the status wire comes on and goes off?
