05 Explorer Sport Trac Alarm install
Acuraxtasy
Member - Posts: 45
Posted: January 15, 2005 at 1:12 AM / IP Logged
In need of wiring/location diagram for 2005 Explorer sport trac.   I have the 01 and 02 versions from Direct tech.  If a link is available I could sure use it......Thanks        05 Explorer Sport Trac Alarm install -- posted image.
KarTuneMan
Platinum - Posts: 7,056
Acuraxtasy
Member - Posts: 45
Posted: January 15, 2005 at 7:49 AM / IP Logged
Thanks KarTune, also I found that if you unplug the gray harness in the pass. kick and toggle the door lock switch you can hear the relays clicking under the dash, which tells me that they are connected to a factory system, however I reconnected the harness and left the vehicle alone till the morning and toggled the door lock switch thru an open window and it worked.  It appears that the CSM doesn't "sleep" and it is always energized.  Just like ford to change something midstream.
Saturday, February 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
