AC doesn't work in remote start
chuntag95
Member - Posts: 39
Posted: October 24, 2002 at 9:46 PM / IP Logged
I have a 1999 Expedition with a Avital 6500 installed.  Everything on it works great except the AC doesn't run in remote start.  The heater works by default, but it seems as if the AC compressor or Automatic controller isn't being turned on.  Is there an extra circuit for the automatic controlled ac units that I need to get powered?  Any help will be greatly appreciated.AC doesn't work in remote start -- posted image.
Regards,
Chris
Sound Pressure
Silver - Posts: 711
Posted: October 24, 2002 at 10:10 PM / IP Logged
Make sure that the accessory is being powered in order for the a/c to turn on.
Sound Pressure
mike simonelli
Member - Posts: 26
Posted: October 24, 2002 at 10:11 PM / IP Logged
There is a yellow 12v, Green purple ing, Black green, Gray yellow there might be 2 of them, red black they all need to be powered.
chuntag95
Member - Posts: 39
Posted: October 25, 2002 at 7:24 AM / IP Logged
Thanks for the info.  I'll check it out and see what's not powered.
Chris
Saturday, August 2, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
