98 montero tach wire
customcarelectr
Member - Posts: 43
Posted: January 20, 2005 at 1:59 PM / IP Logged
doing remote start on 98 montero sport.
everything is great except the unit keeps cranking.
Please tell me the color and location of the correct tach wire.
\the wiring info on this site says the whit ewire at the ecu in the pass. kick panel. well there are two plain white wires there and a smaller gauge white with silver dots.
anyone with experience on this truck?
can I get the tach at the injector or coil?
Thanks in advance
thepencil
Gold - Posts: 1,526
Posted: January 20, 2005 at 2:19 PM / IP Logged
MITSUBISHI, MONTERO SPORT, 1998, Tachometer
On the 2.4L, tach is wht/blk at the coil on the left front of the engine compartment. On the 3.0L and 3.5L it is white at the ignition module next to the coils on the right rear side of the engine compartment under the plastic motor cover.
Be careful whose advice you buy, but be patient with those who supply it.98 montero tach wire -- posted image.
customcarelectr
Member - Posts: 43
Posted: January 20, 2005 at 2:33 PM / IP Logged
Thanks ill check those wires
italnpimp59
Silver - Posts: 427
Posted: January 20, 2005 at 6:13 PM / IP Logged
its at the ECU in the passenger kick panel, white, and in the middle plug.
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
