05 colarado bypass
stang351w
Silver - Posts: 350
Posted: January 24, 2005 at 8:33 PM / IP Logged
i just finished putting in a remote starter in a 05 colarado, i know about the no need for starter wire, but when it came to the bypass, i got lost,  the paper said passlock 2...but no yellow, black (or ORANGE / black) wires for the bypass to hook up to, the tech line said it was an ion set up, but yet once again, that slowed me down another 15 min...grrr... i've got 5 wires, all white with different colour tracers, anyone able to help here?
mo12v
Posted: January 24, 2005 at 9:44 PM / IP Logged
I use the OMEGA PLXR  a LOT easier
Wires up like ION
Some still wire up with 2 Relays & resistors
Some use the DEI 555L
Be sure to hold Ignition Key in CRANK position to get corect Resistance..........It won't hurt it
MO
kgerry
Platinum - Posts: 3,455
Posted: January 25, 2005 at 11:41 AM / IP Logged
i use the PLXR also... find it quick and easy.... 555L doesnt work on this platform....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
stang351w
Silver - Posts: 350
Posted: January 25, 2005 at 2:11 PM / IP Logged
ok well i'm using the plxr bypass module, what wires do i connect to be able to use that bypass?
kgerry
Posted: January 25, 2005 at 2:50 PM / IP Logged
just hook it up as per the ION instructions......
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
stang351w
Silver - Posts: 350
Posted: January 25, 2005 at 6:55 PM / IP Logged
ok, now to sound really dumb here  but i wire it up as a ion system but leave it programd as passlock 2? the reason i think that is i had wired it up as a ion and programd like a ion but it still locked me out for 15 min . unless i did something wrong...which is possible 05 colarado bypass -- posted image.
