problem with autopage rs650 plus
fexploder
Member - Posts: 7
Posted: January 24, 2005 at 11:08 PM / IP Logged
I recently installed an autopage rs650 plus remote start and alarm in my 1999 ford explorer.  The alarm works fine but the that i had to hook up for my third ignition wire is getting no signal from the alarm.  I have checked and tested all wires and when testing the orange wire from the alarm it had no signal when i hit the start button.
ANY information or advice would be helpful
fexploder
Member - Posts: 7
Posted: January 24, 2005 at 11:10 PM / IP Logged
that is the relay i hooked up
metaverse
Copper - Posts: 210
Posted: January 25, 2005 at 11:08 AM / IP Logged
The yellow wire on harness H5 which is a -200ma relay trigger wire for ignition 3. Check your install manual..it says so. Orange wire is always a ground output when armed..used for starter kill relays and/or anti-grind circuitry. Look at the diagram on page 9 of your install manual..it gives you some cartoons to work with..
Wire it up with pole 86 to the yellow wire. Pole 85 and 87 to fused 12v and pole 30 to the third ignition wire.
