2002 Hyundai XG350L Alarm/Remote Start/Stereo Wiring
audiodesign
Member - Posts: 8
Posted: October 27, 2002 at 8:00 PM / IP Logged
 Hey guys thanks for all the info last time on my honda it works great.
I have a friend that wants a viper 550 esp. in his car i just need the alarm wiring diagram for his car 2002 hyundai XG350L w/ trunk release and do i need another relay for the trunk pop. thanks again
Glen
Platinum - Posts: 12,488
Posted: October 27, 2002 at 8:51 PM / IP Logged
|              12V|red (x2)            |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
| SECOND ACCESSORY|brown               |+  |ignition harness            |
|       POWER LOCK|tan                 |5wi|driver door module *1       |
|     POWER UNLOCK|gray                |5wi|driver door module *1       |
|       LOCK MOTOR|tan                 |   |driver door module *1       |
|     UNLOCK MOTOR|gray                |   |driver door module *1       |
|    DISARM DEFEAT|no progressive unlck|   |                            |
| PARKING LIGHTS +|BROWN / white         |   |fusebox, 12 pin plug        |
| PARKING LIGHTS -|lt. blue            |   |headlight switch            |
|       HEADLIGHTS|white               |-  |headlight switch            |
|     DOOR TRIGGER|yellow              |-  |fusebox, 12 pin plug        |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|ORANGE / black        |-  |driver kick panel           |
|         HOOD PIN|lt. blue            |-  |ETACS, 12 pin plug *2       |
|TRNK/HTCH RELEASE|blue                |+  |DKP, 18 pin plug            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|lt. green           |-  |driver door module *1       |
|       TACHOMETER|white               |   |PCM, 26 pin plug *3         |
|      SPEED SENSE|brown               |   |data link connector *4      |
|       BRAKE WIRE|lt. blue            |+  |brake pedal switch          |
|     HORN TRIGGER|yellow              |-  |steering column             |
|           WIPERS|green (L), purple(H)|-  |steering column             |
|  LF WINDOW UP/DN|blue - brown        |A  |LF window switch            |
|  RF WINDOW UP/DN|blue - brown        |A  |RF window switch            |
|  LR WINDOW UP/DN|wht/blk - brown     |A  |LR window switch            |
|  RR WINDOW UP/DN|wht/blk - brown     |A  |RR window switch            |
| SUN RF OPN/CLOSE|yellow - yel/red    |A  |sunroof motor               |
|        RADIO 12V|orange              |+  |radio                       |
|     RADIO GROUND|BLACK/ white         |-  |radio                       |
|     RADIO SWITCH|yellow              |+  |radio                       |
| RADIO ILLUMINATE|BROWN / white         |+  |radio                       |
|    POWER ANTENNA|grn/red (amp remote)|   |radio                       |
|       LF SPEAKER|tan - gray          |   |radio *5                    |
|       RF SPEAKER|tan - gray          |   |radio *5                    |
|       LR SPEAKER|brown - yellow      |   |radio *5                    |
|       RR SPEAKER|brown - white       |   |radio *5                    |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start.  *1 The driver door module is part of the switch assembly on the door panel.  *2 The ETACS module is attached to the back of the fusebox at the top.  *3 The PCM is under the center console to the right of the gas pedal.  *4 The data link connector is under the steering column.  *5 Vehicles that have the upgraded audio system have an amplifier at each speaker.
