Starter kill relay: Polar start PS2965
redled
Posted: January 28, 2005 at 9:11 PM / IP Logged
I'm trying to install a remote starter in my 1997 golf. It's a Polar start PS2965. I got it for next to nothing because it was missing install instructions. I got some faxed from the manufacturer after MUCH running around. I'm all set to install it, but there is one thing on the wiring diagram that I can't make out (it's a poor copy). Here's the wiring diagram:
Starter kill relay: Polar start PS2965 -- posted image.
It's a really large image, so I made it a clickable link. If you click on it and read the not I made on it, can anyone help me with how to wire that part?
draasch
Gold - Posts: 2,172
Posted: January 29, 2005 at 8:52 AM / IP Logged
are you asking about the relay with the red writing?????its for your disable set up......it very easy to do......you will cut your starter wire in two.......the WHITE/ orange from the alarm will go to pin 85...the yellow wire from the alarm that is for your ign., that will hook up to pin 86.....the switch side of the starter wire (it will show 12 volts when you turn the key to the start postion)will go to pin 30 the other cut side will go to pin 87a...
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
muaiad97
Copper - Posts: 207
Posted: January 29, 2005 at 7:41 PM / IP Logged
HI
THAT WIRE ITS STARTER WIRE  AND IT GOS TO STARTER WIRE  FROME IGNITION KEY AFTER YOU CUT THE WIRE IN HALF.
