Remote Start CPX-RS1 on a lawn tractor?
garyk
Posted: February 06, 2005 at 11:15 PM / IP Logged
Has anyone ever heard of putting a remote start on a lawn tractor? I am intrested in trying it out. Any tips would be great and if anyone has the wireing diagram or full manual for the "Car Pro CPX-RS1" Remote Start that would be great...
dsfsdfs
IQinstall
Posted: February 07, 2005 at 2:23 PM / IP Logged
I am sure it could be done, but. As long as it is fuel injected. If not you will have to use a solinoid to pull the choke and or pump the throttle.
astro
garyk
Posted: February 07, 2005 at 3:11 PM / IP Logged
its not fuel injected but i was going to order a small actuator to do it and build a circuit to keep it up for 30 seconds and take it down after 30. my other only problem is the tach point.
dsfsdfs
Platinum - Posts: 12,488
Posted: February 07, 2005 at 3:22 PM / IP Logged
Use alternator sensing if you could or if the unit supports a tachless mode, use it instead.
harveje
Member - Posts: 13
Posted: February 07, 2005 at 9:16 PM / IP Logged
Now that AWESOME you will have to put flames on it now....Remote Start CPX-RS1 on a lawn tractor? -- posted image.
davedyer79
Copper - Posts: 178
Posted: February 08, 2005 at 4:11 PM / IP Logged
I put an Autopage 615 remote start on my Great Dane.  It has the 28 hp Kohler fuel injected motor.  Pretty easy, only one ignition wire.  I just wired my brake wire to a small toggle unit mounted by the seat.  Also, I built a small fiberglass case to house the remote start in, along with the factory computer.  Works great, really frieks people out when you get ready to mow!!!
davedyer79
oonikfraleyoo
Gold - Posts: 1,069
Posted: February 13, 2005 at 1:20 AM / IP Logged
I know this is probly like when older people ask me why I like my music so loud (if I have to tell you, you won't understand) But why?
soundmasta
Silver - Posts: 246
Posted: February 14, 2005 at 8:01 AM / IP Logged
i understand.
