alarm install questions
Jimmy 2 Times
Copper - Posts: 67
Posted: February 08, 2005 at 12:31 PM / IP Logged
Okay, so i was installing a matrix 2.5 in my 01 Camaro with a 6 speed manual trans.  I had everything working fine, but as soon as i would put my foot on the clutch, the car would start.  I tested all wires agaisnt what direct techs said, and it still starts with my foot on the clutch??? possibly a bad relay maybe??? can someone help me out here
thanks
jimmy
draasch
Gold - Posts: 2,172
Posted: February 08, 2005 at 2:16 PM / IP Logged
sounds like you have a relay wired up wrong.....how did you wire it up????
im assuming you did a clutch by-pass
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Uniqueauto
Copper - Posts: 73
Posted: February 08, 2005 at 2:53 PM / IP Logged
A Clifford matrix 2.5 is not a remote start. Do you mean a 3.5?
Installer/Owner
Double check twice Install once!
Wires are my Best Friends
Jimmy 2 Times
Copper - Posts: 67
Posted: February 08, 2005 at 4:40 PM / IP Logged
no, it was a 2.5 i was wiring up the starter kill relay, i did nothing with a remote start
jimmy
gcorrea
Silver - Posts: 436
Posted: February 09, 2005 at 12:01 AM / IP Logged
your probably feeding 12volts back to the starter wire somehow. recheck your kill relay. if in doubt look in this site for the relay wiring.
gcorrea
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
