97 tiburon help
timkel
Posted: February 13, 2005 at 1:20 PM / IP Logged
I need the wiring diagram  for the door locks and  power windows.
iskidoo
Silver - Posts: 1,046
Posted: February 13, 2005 at 2:11 PM / IP Logged
You need to add an aftermarket door actuator on this vehicle.
Power Lock    (add actuator in drivers door)
Power Unlock (add actuator in passengers door)
Left Front Window UP-blue/white
Left Front Window DOWN-BLACK / YELLOW
Type: A
Right Front Window UP-blue/white
Right Front Window DOWN-BLACK / YELLOW
Type: A
timkel
Posted: February 14, 2005 at 12:28 AM / IP Logged
It already has power door locks factory .What is the wiring for the factory door locks? thanks
secureauto
Copper - Posts: 197
Posted: February 14, 2005 at 12:46 AM / IP Logged
What iskidoo is explaining is the Tiburon has a central door locking system, the passenger doorlock requires physical movement of the driver doorlock plunger for it to lock/unlock. Adding an actuator in the driver door is required.
ASE Certified
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
