Questions about My Viper 300 alarm
xdeliriousx
Member - Posts: 14
Posted: February 14, 2005 at 12:49 PM / IP Logged
Hi, I just bought a used car and want to make some changes to the settings on the alarm.
I'm following the instructions to setup the viper, but I must be missing something because the alarm doesn't seem to respond.  Basically start off sitting in the car (key in my hand and door closed).  I open the door.  Put the key in the ignition, start the engine, immediately turn off the engine, go to the valet switch (an on/off position switch, which is at "off").  I move the switch to the ON position, Off position, On position, off position, on position, off position, and finally ON position and keeping it there.  Supposely the alarm should give me three chips indicating that I'm in option menu #3 right?  (all while the door remained opened).  The alarm was professionally installed, I'm trying to add ignition door lock feature.  I'm following the instructions to setup the viper, but I must be missing something because the alarm doesn't seem to respond.  Basically start off sitting in the car (key in my hand and door closed).  I open the door.  Put the key in the ignition, start the engine, immediately turn off the engine, go to the valet switch (an on/off position switch, which is at "off").  I move the switch to the ON position, Off position, On position, off position, on position, off position, and finally ON position and keeping it there.  Supposely the alarm should give me three chips indicating that I'm in option menu #3 right?  (all while the door remained opened).  The alarm was professionally installed, I'm trying to add ignition door lock feature.
Another question is that I'd like to buy a remote trunk release for this car.  If I buy the DEI trunk device, when popping the trunk open, does it disable the alarm?  can anyone explain how it would work?   Since right now, if the car is armed, opening the trunk (manually) will set off the alarm.
Last but not least, I found some cheap trunk release on ebay for about $20 shipped, versus $50 shipped for a DEI branded one, is there a difference?  Which should I get.  Thanks
David
auex
Platinum - Posts: 5,041
Posted: February 14, 2005 at 4:40 PM / IP Logged
Leave the door open, don't crank but just turn to run then off, then hit the valet button accordingly. Also ign locks by default is on. One thing that would explain both problems is that the ign wire may be hooked up incorrectly.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
xdeliriousx
Member - Posts: 14
Posted: February 16, 2005 at 4:01 AM / IP Logged
Hrm, still didn't get it to work yet.  Will try that this weekend.
Can anyone answer my other questions though?  About the trunk release>
David
xdeliriousx
Member - Posts: 14
Posted: February 16, 2005 at 4:32 PM / IP Logged
Actually I did look at that, but it doesn't tell me how the remote trunk release would work.  I just want to know if it will disable the alarm when the trunk is poped.
David
probeguy84
Posted: February 16, 2005 at 9:19 PM / IP Logged
are you sure the toggle switch is plugged into the blue port on the alarm and not hooked up as a rem. start kill?
check the alarm to be sure.
93/89 PGT's
CutDog504
Silver - Posts: 643
Posted: February 22, 2005 at 12:47 AM / IP Logged
Is this a viper 300, a 300+ , or a 300esp ??? Is the little light on the keypad red or green. Because the 300 and the 300+ were the older ones that came with the red light keypads. Bad news if you do have the red light keypad....those alarms do not have the ign doorlock feature. Only the newer ones (the esp) are capable of doing the ignition controlled doorlocks. But as for the trunk release, yes they all have a 2nd channel output. And yes, it will bypass the alarm when you pop the trunk, but only if you have a mercury switch or trunk pinswitch installed and connected to the blue wire. As soon as you pop the trunk using the remote, all sensors become bypassed and as long as the the alarm "sees" the trunk open, it will continue to bypass all sensors and continue to do so until 5 to 7 seconds after the trunk is shut.
xdeliriousx
Member - Posts: 14
Posted: February 22, 2005 at 11:31 PM / IP Logged
Thanks for all the help guys!
That trunk release is too cool!  It even rearms the car for you!  that's nice.... Since I often disarm my car to manually open the trunk and then forget to rearm the car.  I got good news for myself :) I checked my Viper 300 (original 300)'s manual on http://www.drdetailshop.com/deiinstallguides.htm  and found that it does have the ignition controlled door locks.  I will take it to a friendly mechanic this weekend to get the feature turned on.
David
Thursday, December 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
