Remote Starter Question
robbyw
Posted: March 01, 2005 at 12:24 PM / IP Logged
I just installed an Omega Remote Starter on my 1972 Dodge Dart Swinger. Before I got the car, my friend installed an electronic ignition. 1 day after installing the remote starter, my resistor went out. I bypassed it long enough to get home (about 15 miles from school to the house). Today, I installed a resistor off of my Dodge Satellite and it worked for a while, but then after a few minutes it too went out. However, when I tried to bypass it this time, It wouldn't even fire. Is there a chance that I burned up the new electronic ignition? Also, could the remote starter cause the resistor to burn up like that because I had to tap into the ignition wire?
I can do all things through Christ who strengthens me
bretbowman
Copper - Posts: 156
Posted: March 02, 2005 at 2:30 AM / IP Logged
Could I suggest buying a newer model car without causing any offense to you?
2002 Toyota Sequoia Limited 2WD (Clifford G5 Avantguard 5 w/ 2 SmartWindows modules) - IT Engineer - NRA Life Member - LDS Return Missionary - Married for time AND ETERNITY - Eternally sealed family
dare_ds69
Silver - Posts: 419
Posted: March 02, 2005 at 6:46 AM / IP Logged
you have to make sure the exact resistence that you need and use a relay.
how own your mind, control your life.
MECP certified. always use a DMM
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
