2004 Saturn Ion alarm wiring
Welcome Guest :)
rynomobility
Member -
Posted: March 02, 2005 at 12:37 PM / IP Logged
Can someone provide and alarm wiring diagram for this year vehicle. Thank you very much
rynomobilitycorp@aol.com
edward m pic
Bnluis
Silver -
Posted: March 02, 2005 at 12:48 PM / IP Logged
To print: Click here or Select File and then Print from your browser's menuTo close this window: Click here or click the X at the top right of this window.
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | See Note Below* | See Note Below* |
Ignition #1: | | Pink | IGNITION SWITCH HARNESS |
Ignition #2: | | | |
Ignition #3: | | | |
Accessory: | | Brown | IGNITION SWITCH HARNESS |
Brake Light: | | BLUE (+) | Above the brake pedal switch |
Tach Signal: | | | |
Parking Lights: | | Brown | BCM |
Headlights: | | | |
Diesel Glow Plug: | | | |
Clutch Bypass Wire: | | | |
Notes: | | * Two relays and resistors will have to be obtained. Please call for more notes and information. Or you can purchase a vehicle specific bypass module part number 23571. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | WHITE/ BLACK | IGNITION SWITCH HARNESS |
OEM Alarm Disarm: | | | |
Dome Lights/Superv: | | | |
OEM Horn: | | GREEN (-) | STEERING COLUMN |
Power Lock: | | White | BCM |
Power Unlock: | | Single wire door lock | |
Trunk Release: | | | |
Alarm Input Wire: | | | |
Notes: | | **BCM found in the passenger's kick panel behind the fuse box. Please see note 211 for negative door lock systems. Lock is a negative pulse and unlock need a 1.5K ohm negative pulse. |
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
rynomobility
Member -
Posted: March 02, 2005 at 1:57 PM / IP Logged
Thank you for the information we greatly appreciate it.
edward m pic
ccroadshop99031
Copper -
Posted: March 02, 2005 at 1:58 PM / IP Logged
i think this is one of the gm's that cranks when the computer sees accessory drop
Platinum -
Posted: March 02, 2005 at 2:33 PM / IP Logged
Yes it is. You will need the proper bypass module as well ( PLXR ) to make the remote start work.
Wednesday, April 22, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
