Posted: March 02, 2005 at 10:04 PM / IP Logged
Posted: March 02, 2005 at 10:48 PM / IP Logged
Posted: March 03, 2005 at 5:27 PM / IP Logged
Posted: March 03, 2005 at 7:22 PM / IP Logged
Posted: March 03, 2005 at 7:55 PM / IP Logged
Posted: March 04, 2005 at 12:41 PM / IP Logged
Posted: March 04, 2005 at 5:33 PM / IP Logged
Monday, April 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
), in climates where it gets down to around 5 or 10 degrees, what do you recommend to set the tach at? Also, does the tach learning only remember the "idle" RPM, or does it also remember the RPM when it started? I ask because it says to enter learning mode first, then start the car and wait for low idle before "setting" it. If so, I could just rev the engine when starting the car to learn the tach signal. Then it may see 2000+ RPM at starting as being acceptable.
I'd like to make sure the tach change I made fixed it.
