automatic door lock wiring
iroc530
Posted: March 03, 2005 at 3:11 PM / IP Logged
hi i need help wiring my new door lock actuators to my alarm the actuators have a green and a blue wire the alarm has orange wire that is activated when the alarm is on and deactivates when the alarm is off the alarm is a hornet 719t if that helps so im trying to figure out a way to wire it or use a relay or something so when the alarm is armed my doors lock and the alarm is off they unlock any help would be great
Ween
Platinum - Posts: 1,368
Posted: March 03, 2005 at 6:10 PM / IP Logged
if the 719t doesn't have lock and unlock outputs,  you can use a dei 452t which will give you the pulses to trigger relays which in turn will operate the actuators.  in any case you'd need two relays.
iroc530
Posted: March 03, 2005 at 6:25 PM / IP Logged
i also bought this http://www.eenid.us/cs-6600dlm.html
iroc530
Posted: March 03, 2005 at 7:48 PM / IP Logged
ok so i found the item bought it for 8 bucks at a local alarm shop does anyone know how to wire this thing to my alarm ?
Ween
Posted: March 03, 2005 at 8:01 PM / IP Logged
which item are you refering to...the crimstopper or dei piece?
iroc530
Posted: March 03, 2005 at 9:55 PM / IP Logged
i bought the dei thing the crime stoper thing i returned u said i needed some relays which ones do i buy and how do i wire them up
iroc530
Posted: March 03, 2005 at 11:00 PM / IP Logged
alrighty everything works its 9 pm in california 12 hours of work mainly internet time and i got it Ween you are the man much thanks
