1995 Lincoln Towncar 791xvr
IIrjII
Copper - Posts: 103
Posted: March 15, 2005 at 5:32 PM / IP Logged
i am currently working on a 95 Lincoln Towncar and installing a remote start system on the vehicle.  The install is finished, but when I remote start the vehicle, the car will remote start for a little bit, die, remote start again on its own, and run for a shorter time, die, and then remote start again, and die at an even shorter period.  Does anyone have any info they can throw my way?  Thanks
dare_ds69
Silver - Posts: 419
Posted: March 15, 2005 at 5:40 PM / IP Logged
you did tach or tachless?
how own your mind, control your life.
MECP certified. always use a DMM
IIrjII
Copper - Posts: 103
Posted: March 15, 2005 at 5:42 PM / IP Logged
When I hooked it up, I started on tach, and the starter would engage and would not disengage.  When I hook up as voltage, the starter is a clean start but then the remote start just does what I stated up above.
dare_ds69
Silver - Posts: 419
Posted: March 15, 2005 at 5:50 PM / IP Logged
did you pragram the tach? I do alot of DEI and if the led do not stay solid during the tach program means it is wrong, if you go for voltage you have to program to, plas use the (*) don't use the 2 bottons on top because it is turbo timer 1 minute
