1999 nissan pathfinder alarm bypass
madBedex
Member - Posts: 17
Posted: March 26, 2005 at 2:19 PM / IP Logged
Would someone please tell me,how to bypass the factory alarm for nissan pathfinder.I installed an after market alarm on it.
accidently,when,the factory alarm goes off , the customer call me.And the truck can't even start at all.It would be greatly appreciated,if someone could send me the info.how to bypass it.
thanks!
madbedex
KarTuneMan
Platinum - Posts: 7,056
Posted: March 26, 2005 at 4:03 PM / IP Logged
If your alarm has door lock out puts and you used them....you need to double pulse the unlock. First pulse
will disarm, and the second will unlock. This truck arms and disarms with the lock and unlock. There really
shouldn't be a problem
masterk
Member - Posts: 19
Posted: March 26, 2005 at 8:04 PM / IP Logged
Need help 1994 Nissan Sentra installing remote start only works when key is in ignition  when key is not in trys to start then cuts off.Not sure about ign2 connected to blk / yl cold start , wires are different colors on each side of ignition harness
8d
crawford7827@bellsouth.net
masterk
Member - Posts: 19
Posted: March 26, 2005 at 8:05 PM / IP Logged
Need help 1994 Nissan Sentra installing remote start only works when key is in ignition  when key is not in trys to start then cuts off.Not sure about ign2 connected to blk / yl cold start , wires are different colors on each side of ignition harness1999 nissan pathfinder alarm bypass -- posted image.
8d
