starter immobilizer
rock1
Copper - Posts: 120
Posted: April 06, 2005 at 12:53 AM / IP Logged
I have an 3in1 alarm and have a question. Can I still install the starter immobilizer relay without cutting the factory wiring. Im testing this alarm out and dont want to cut it and knowing that I dont like it. if I install it wihout cutting will it still work?
dare_ds69
Silver - Posts: 419
Posted: April 06, 2005 at 5:43 AM / IP Logged
no because you have to cut the start wire
how own your mind, control your life.
MECP certified. always use a DMM
misterjimbo
Silver - Posts: 535
Posted: April 06, 2005 at 10:26 AM / IP Logged
dont worry about it you can always put it back together if you decide that you do not like it.
rock1
Copper - Posts: 120
Posted: April 06, 2005 at 10:48 AM / IP Logged
I thought that you can just connected it all together without cutting any factory wiring. the same way you slice the wire in the middle and then wrap around it. someone had the same problem and the car started then cut off seems like he did not cut the factory wiring.
csorb
Copper - Posts: 317
Posted: April 06, 2005 at 6:28 PM / IP Logged
If you're going to install the whole alarm and then take it out,it won't make much difference if you also cut the starter wire. You can do everything but the starter wire if you'd like and just listen to the relay to make sure it works.
nava94
Silver - Posts: 296
Posted: April 06, 2005 at 9:23 PM / IP Logged
 There is one company that makes an aftermarket harness that is just plug and unplug for the ignition cylinder. so you could install an alarm and if you don't like it you could unplug the aftermarket ignition harness and plug your factory ignition harness back into your ignition cylinder and you won't have to cut no starter wire. i don't know the company that make this harness but I've seen these harnesses there kool and the gang.
rock1
Copper - Posts: 120
Posted: April 09, 2005 at 9:12 PM / IP Logged
instead of cutting the wire cant you just slice into the wires and wrap around it. instead of making end to end connections just strip back one inch of the insulation and slice in the middle of the wire.
Monday, November 3, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
