98 crv output for factory keyless?
yellaboi
Posted: April 06, 2005 at 10:08 AM / IP Logged
I would like to install a window rollup module to a 98 crv.   Iwas wondering if it has an output from the factory keyless . and if so where is it?
thepencil
Gold - Posts: 1,526
Posted: April 06, 2005 at 10:30 AM / IP Logged
Hope this is what you are looking for.
DIRECTWIRE™ WIRING INFORMATION - HONDA / CR-V / 1998 / Accessory
12volts white   +   ignition harness
Ignition BLACK / YELLOW   +   ignition harness
Parking Lights+ RED / black   +   dash dimmer
Parking Lights- blue/red   -
Notes: This wire only works if there is a factory alarm installed. It is at the green factory alarm plug in the driver kick.
Headlight RED / white   +   headlight switch
Trunk/Hatch Release yellow   +   release switch
Power Sliding Door
Speed Sense blue/white      instrument cluster or PCM
Notes: The PCM is in the passenger kick panel. VSS is in the 31 pin plug, pin 23.
Also found at the cruise control module in the driver kick, if equipped.
Wipers blue (L), blue / YELLOW (H)   -   windshield wiper switch
LF Window up/dn RED / blue - RED / yellow   A   power window switch
RF Window up/dn blue / YELLOW - blue/orange   A   power window switch
LR Window up/dn GREEN/ YELLOW - green   A   power window switch
RR Window up/dn yellow - YELLOW /GREEN   A   power window switch
Sun Roof open/close
Sun Roof Limit/close
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.98 crv output for factory keyless? -- posted image.
yellaboi
Posted: April 06, 2005 at 10:35 AM / IP Logged
thanks for the info but I already have this. I guess a better question would be what would be a good trigger for the module. I want to wire it so the module triggers when the doors are locked by the factory keyless.
