04 civic fact. keyless
mxxmikexx
Silver - Posts: 796
Posted: April 07, 2005 at 1:30 PM / IP Logged
does the factory keyless entry still work through the radio on the 04's like they did on the earlier 00's? and i also seem to remember the domelight circuit working the same way. Im going to be doing a deck swap on an 04 civic and installing a new alarm/keyless, just wanted to know of any problems i might run into ahead of time. thanks!
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
misterjimbo
Silver - Posts: 535
Posted: April 07, 2005 at 1:49 PM / IP Logged
not that i am aware of. i have an 03 ep, it is a different chassis than the one you are doing, but the same radio. you should not have any problems.  even if it does not have a factory alarm there should still be a green plug above the drivers kick panle that has locks door triggers pk lights and such
auex
Platinum - Posts: 5,041
Posted: April 07, 2005 at 4:05 PM / IP Logged
No, 96-98 only.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
