88 Dodge Van alarm wiring
mustang87
Member - Posts: 12
Posted: April 11, 2005 at 1:51 PM / IP Logged
I have an 88 Dodge Van 250 I am trying to install a Viper alarm into.I am trying to find the wire colors for the door locks and the door pins.
Any help appreciated.
Thanks in advance88 Dodge Van alarm wiring -- posted image.
mustang87
mo12v
Posted: April 11, 2005 at 2:25 PM / IP Logged
RAM  VAN:
Constant 12 voltsRED AND PINKIGNITION SWITCH HARNESS
Ignition 12 voltsDARK BLUEIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightYELLOW OR WHITE(-) AT PIN SWITCH
Trunk Pin SwitchSAME AS ABOVEREAR DOORS SAME CIRCUIT AS OTHERS
Parking LampBLACK / YELLOW(+) AT LIGHT SWITCH
Power LockORANGEDRIVER KICK PANEL OR
Power UnlockPINKBEHIND GLOVE BOX
Reversal Rest At Ground Door Locks
Accessories
Window UpD\ L BLU P\ BRN @ MAIN SWITCH
Window DownR/ WHT S/ VIO
Ign Key WarnLIGHT BLUE(-) STEERING COLUMN HARNESS
Trunk ReleaseN/A
OEM HornBLACK/ RED(-) STEERING COLUMN HARNESS
HeadlightsLIGHT GREEN(+) AT HEADLIGHT SWITCH
OEM Alarm ArmN/A
OEM Alarm DisarmN/A
 Reversal Rest At Ground Power Window Circuit
Remote Start
Tach SignalBLACK/ GRAY ORBLACK / YELLOW - AT COIL *
Ignition #2BLACK/ REDIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryBLACKIGNITION SWITCH HARNESS
Neutral SafetyBROWN / YELLOWAT SWITCH
Brake LightWHITE(+) AT SWITCH
Reverse LightVIOLET/BLACKAT SWITCH
Rear Window Defrost
* Some Models Carburated
MO
mustang87
Member - Posts: 12
Posted: April 11, 2005 at 3:29 PM / IP Logged
Thank you very much!!! Just one more quiestion if you don't mind.Is there anything special I have to do with relays?
mustang87
mustang87
Member - Posts: 12
Posted: April 16, 2005 at 11:05 AM / IP Logged
does anyone know it my van is reverse polarity on the lock relays???
mustang87
mo12v
Posted: April 16, 2005 at 4:59 PM / IP Logged
Means, 5 wire .......2 SPDT Relays  1 for LOCK & 1 for UNLock
Try:
https://www.the12volt.com/doorlocks/page3.asp#5w
MO
mustang87
Member - Posts: 12
Posted: April 16, 2005 at 10:44 PM / IP Logged
Thank you Very Very much!!!!
Sorry About the all Caps before I was about to explode.
mustang87
