791xv ground when armed output & starter
Justducttapeit
Posted: April 13, 2005 at 1:49 AM / IP Logged
I have a 791xv by VIPER, do I connect the "GROUND WHEN ARMED OUTPUT" to the starter wire?  Thus it provides a ground for the starter "when armed"? So it won't work?  That is my guess, but I'm most likely wrong.  The more I think about it thats the only place I can think of.  I tried just grounding the ground when armed output and it just didn't change anything.  Everything works, except the starter works when it's armed and the anti-grind doesn't work.  Thanks
Brady
Brady Anderson
1994 Honda Accord EX
Pocatello, ID
dare_ds69
Silver - Posts: 419
Posted: April 13, 2005 at 6:52 AM / IP Logged
if you read the instructions u should know that the viper came with anti-grind relay done for u, the orange wire don't use it, use just green and purple fron the satelite relays. purple goes to motor side and  green goes to key side.
how own your mind, control your life.
MECP certified. always use a DMM
Justducttapeit
Posted: April 13, 2005 at 10:39 AM / IP Logged
ok, what exactly does "key side" mean? and "motor side"?My anti grind doesn't work though...it may have something to do with my purple and green wires tho. Thanks
Brady Anderson
Pocatello, ID
vt_hokie2008
Copper - Posts: 84
Posted: April 13, 2005 at 12:09 PM / IP Logged
you cut the starter wire and put the green on the end of the wire closest to the key and the purple goes on the other side of the cut wire.
