01' ford explorer door locks
mxxmikexx
Silver - Posts: 796
Posted: November 13, 2002 at 11:52 AM / IP Logged
does anyone have information on hooking up door locks on this vehicle. my techsoft program says the circuit shuts off after the vehicle is left off after a certain period of time, and you need to "wake up" the circuit when interfacing with the door locks. i guess i need document number 1093 if anyone out the uses DEI techsoft info. any help appreciated!!!!!
Player69
Silver - Posts: 504
Posted: November 13, 2002 at 1:46 PM / IP Logged
All you have to do to bypass the BCM shutdown is pulse the BLACK / YELLOW wire in the drivers kick with a - pulse before the doors unlock.   This output on your remote start might be labeled as pulse before or factory alarm disarm.
djfearny2
Silver - Posts: 810
Posted: November 13, 2002 at 4:25 PM / IP Logged
EITHER DO THAT OR SET THE ALARM TO DOUBLE UNLOCK PULSE AND DIODE ISOLATE THESE WIRES TOGETHER WITH THE UNLOCK WIRE FROM THE ALRM. AND WHAT WILL HAPPEN IS THE FIRST UNLOCK PULSE WILL WAKE UP BRAIN AND SECOND WILL OPEN THE DOORS , YOU CAN USE THE DRIVERSIDE REAR DOOR PIN TO WAKE UP THE DOOR LOCK MOD CALLED THE GCM OR SOMETHING.
Jon
Installer/Help Technician
---coral springs florida---
