2005 Camry Alarm needed
sburro2
Member - Posts: 19
Posted: April 19, 2005 at 10:01 AM / IP Logged
I've purchased a '05 Camry LE with keyless entry. The dealer wants $699 for an alarm (Checkmate). The dealer tells me they can interface the alarm right to the OEM keyless entry. A price of $700 does not sit well with me.
Does anyone know where I can buy the alarm from (other than the dealer) with instructions on how to code to the Camry key fob?
Thanks in advance
mo12v
Posted: April 19, 2005 at 7:09 PM / IP Logged
There are other Alarms available that will also work with the Toyota Camry Keyless as well as other Vehicles.
OMEGA  .... AL-100H
MO
sburro2
Member - Posts: 19
Posted: April 20, 2005 at 2:22 PM / IP Logged
Thanks for the information.
nava94
Silver - Posts: 296
Posted: April 21, 2005 at 8:19 PM / IP Logged
yeap along with the dei oem upgrade alarm hornet  700t. all the features of an alarm the only thing is you use the keyless entry remotes to arm/disarm the alarm.
Platinum - Posts: 12,488
Posted: April 21, 2005 at 9:19 PM / IP Logged
Thanks in advance
WOW ... for $ 700 I can have a 2 way Compustar system installed for you with the remote start & keyless entry. That seems really high to me. Have you tried shopping around for this system elsewhere ?
sburro2
Member - Posts: 19
Posted: April 22, 2005 at 7:15 AM / IP Logged
At this point I will be installing for myself. The Hornet 700t seems like a good unit. Any advice\comments about that alarm would be appreciated..
Wednesday, May 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
