03 Tahoe Locks-Unlocks
remote possib
Posted: April 21, 2005 at 10:26 PM / IP Logged
Not having any luck getting the DEI-456G to work
Do I need to go into the doors to hook up wires
Any help would be great thanks.
Bmnicolosi
Copper - Posts: 173
Posted: April 22, 2005 at 10:08 AM / IP Logged
no all you should ned is that piece which connects to the databus wire
If you say "I already know how", don't ask me a single question.
KarTuneMan
Platinum - Posts: 7,056
Posted: April 22, 2005 at 10:15 AM / IP Logged
you DO need to connect the alarm lock and unlock outputs to the 456G ?
I dont know what the problem could be.....can you give us more info on how you installed it?
floaterr
Silver - Posts: 383
Posted: April 22, 2005 at 4:05 PM / IP Logged
Drop us a line on what alarm it is too. That way someone can make sure to give you all the right wiring instructions
remote possib
Posted: April 26, 2005 at 12:13 PM / IP Logged
Sorry for not getting back sooner
Remote start -Prestige APS-55LRA
Audoivox Passlock 2
Directed ele. 456G
I someone can help me on where to look for the Data bus out put and where I need to hook the door wires that would be great  Thanks
Captanham
Silver - Posts: 365
Posted: April 26, 2005 at 2:19 PM / IP Logged
the databus wire is found on your obdII port, it's a black plug on the drivers side under the dash, it will have 4 wires going to it (usually) it's usually the purple one that you will have to connect to, the wires from your alarm will go into your modual, you will not touch the doors
Bad Boys Customs
    audio - video - security
If you use it. Suport it. Donate to the 12 volt!
Wednesday, May 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
