91 toyota mr2 turbo wiring diagram
mr2_503
Posted: November 15, 2002 at 2:58 PM / IP Logged
Could any body give me the diagram for a 91 toyota mr2 turbo wiring diagram Please
Platinum - Posts: 12,488
Posted: November 15, 2002 at 4:08 PM / IP Logged
|              12V|BLACK/ red - white   |+  |ignition harness            |
|          STARTER|red                 |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ orange        |+  |ignition harness            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
|       POWER LOCK|black               |-  |passenger kick panel        |
|     POWER UNLOCK|BLACK / YELLOW        |-  |passenger kick panel        |
| PARKING LIGHTS +|green               |   |drivers kick                |
| PARKING LIGHTS -|lt.GREEN/ red        |   |steering column             |
|       HEADLIGHTS|red                 |-  |steering column             |
|     DOOR TRIGGER|RED / white           |-  |either kick *2              |
|  TRUNK/HATCH PIN|RED / green           |-  |theft ECU                   |
|         HOOD PIN|tied with trunk pin |   |                            |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
|       TACHOMETER|BLACK/ white         |   |check connector *1          |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake switch                |
|     HORN TRIGGER|GREEN/ black         |-  |steering column             |
|           WIPERS|blue/black          |+  |wiper switch or column      |
|  LF WINDOW UP/DN|green - red         |A  |in drivers door             |
|  RF WINDOW UP/DN|RED / blue - green    |A  |in drivers door or dkp      |
Notes:
*1 The check connector is on the right rear of the engine compartment.  *2 This wire can also be found at the theft ECU, which is located on the passenger side behind the "B" pillar trim.
mr2_503
Posted: November 15, 2002 at 5:02 PM / IP Logged
Jeff,
Thanks for the quick reply.  I do have a quick question for you, for the wire location, when you say ignition harness, do I spliced the female or male adapter, same for steering column and theft ecu.
Posted: November 15, 2002 at 11:16 PM / IP Logged
The locations are the wires that you have to tap into the insulation . You want to peel back the insulation on the target wires and wrap the wires that you have on the alarm or remote starter unit and solder the connection .
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
