gta
tekk
Member - Posts: 18
Posted: April 29, 2005 at 4:56 PM / IP Logged
I have a '91 Buick which until recently I was not aware had a security system. I unplugged the battery to install a new radio and now the car will not start. The accesories work, the radio plays flawlessly but the car will not start. What do I need to do?
NoPo 4 Life
tekk
Member - Posts: 18
Posted: April 29, 2005 at 5:58 PM / IP Logged
Not all at once now fellas.
NoPo 4 Life
auex
Platinum - Posts: 5,041
Posted: April 29, 2005 at 7:37 PM / IP Logged
What the hell of a title is GTA for this thread? If you where to give it a title that gave someone some insight as to what they were clicking then maybe you would get some help.
At anyrate, get a butt connector. Then go under the dash and look for the starter wire, should be purple or yellow. It will also be cut and both ends should be running to a relay. Cut the starter wire away from the relay and reconnect with the butt connector. You could also try pulling the fuse for the alarm. The first recomendation is more permanent.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
