toad 101 cl
ace.3
Member - Posts: 8
Posted: May 07, 2005 at 9:11 PM / IP Logged
does anyone have the dual zone proxy sensor wires into the alarm ie were do they attach to as they go into the alarm on the 4 pins.
kps67
Member - Posts: 25
Posted: May 08, 2005 at 3:19 AM / IP Logged
You can color match the wires with the shock sensor if it is made by the same copmany using diodes. If not check to see if your alarms has auxilary alarm trigger that you can connect teh proximity sensor to.
ace.3
Member - Posts: 8
Posted: May 08, 2005 at 6:09 PM / IP Logged
cheers m8 all sorted now.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
