2005 Taurus BCM? Slamlock?
speedracertjl
Member - Posts: 32
Posted: May 10, 2005 at 8:24 PM / IP Logged
i just did a basic keyless on a base model '05 taurus and it has the usual symptoms of a sleeping BCM or the Slamlock system on the newer ford trucks.If if sits for awhile the keyless dont work..i also noticed if you lock door using the lock button on the door and then shut the door after 2 minutes the unlock button wont work(ive read that this means its the slamlock system) ive been told you can tag the keysense wire with the unlock wire using a diode and i did that with no results.and i also did not find a disarm wire in the boot(which makes sense since i didnt find a factoty alarm present)..any ideas anyone? thanks in advance
Ween
Platinum - Posts: 1,368
Posted: May 10, 2005 at 9:07 PM / IP Logged
maybe pulse one of the door latchs/pins with unlock, not sure of polarity.  set door unlock to double pulse.
mark
Platinum - Posts: 12,488
Posted: May 10, 2005 at 9:41 PM / IP Logged
Try pulsing the door trigger wire ( The LF door trigger is yellow/black in pin 5 at the GEM ) and this will fool the car into thinking that a door was open. Pulse this wire along with the unlock wire and diode isolate each wire.
speedracertjl
Member - Posts: 32
Posted: May 10, 2005 at 9:44 PM / IP Logged
UPDATE: i set the keyless to double unlock pulse and noticed that if you power up the ignition it wakes up whatever need to be woken up..so i took a relay and used it to trigger the ignition(triggers ignition on the 1st pulse and the Unlock on the second) and that worked or so i thought..the customer just called me and said his "AIRBAG" light is on.not sure if thats because of the quick ignition pulse? anyway..ive installed a dozen or so keyless and/or remote starts on '03+ taurus/sable in the past 6 months and have never had a problem.any suggestions? lemme know.thanks guys
speedracertjl
Member - Posts: 32
Posted: May 10, 2005 at 9:47 PM / IP Logged
Hey Jeff thanks for the suggestion..where exactly is the GEM module? i was of the impression that its inside the fuse box(the wires coming out of the bottom of the fusebox)this should be + right? also..when i was in the kick/door sill/door boot i handnt noticed a i believe it was blk/blu + door trigger that showed a + when the driver door was open.
Posted: May 10, 2005 at 10:25 PM / IP Logged
The GEM on the Tauraus' are in the base of the center console to the right of the accelorator pedal. There will be 3 plugs that will have all the connections for keyless, OEM alarm, trunk, door trigger's etc.....
NowYaKnow
Gold - Posts: 1,217
Posted: May 11, 2005 at 5:36 PM / IP Logged
Look for a plug on the BCM near the front bottom where the driver puts their feet. There should be 3 plugs in a row not sure which one offhand, but it should have some or all of the following colors: pink/green, pink / YELLOW, tan/light green, purple / YELLOW, pink/white, yellow/black. It will have your lock/unlock/trunk/OEM hood pin (if equipped)/OEM Alarm Disarm (if equipped)/and driver door latch.
You want to branch your negative unlock wire, put 2 diodes inline, and hit the pink/green unlock wire, and the yellow/black drivers door latch wire. You will need to set the unit to double pulse unlock as well.
Mike
speedracertjl
Member - Posts: 32
Posted: May 11, 2005 at 10:09 PM / IP Logged
thanks mike ill try that but your talking about the bcm on the left of where the driver puts his feet right?
NowYaKnow
Gold - Posts: 1,217
Posted: May 11, 2005 at 10:18 PM / IP Logged
"thanks mike ill try that but your talking about the bcm on the left of where the driver puts his feet right?"
Yeah that big mess in the drivers underdash area. The plug your looking for will be more on the bottom of it. It's very accessible and easy to unplug pretty much right in your face, so if your killing yourself trying to get it your looking in the wrong place. Like I said look in those plugs for the normal lock/unlock wires and the yellow/black wire will be in the same plug. If not, it's coming in from the drivers door boot.
Mike
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
