2002 mitsubishi montero diagram
laoreflxzn
Member - Posts: 12
Posted: November 18, 2002 at 12:17 PM / IP Logged
does anyone have the diagram for the montero?  thanks
laoreflxzn
Member - Posts: 12
Posted: November 18, 2002 at 12:19 PM / IP Logged
and for the 2000 montero also
skerr
Copper - Posts: 52
Posted: November 18, 2002 at 1:07 PM / IP Logged
2000 Mitsubishi Montero Security Information
Constant 12V+White Ignition Switch Harness
StarterBlue/Black Ignition Switch Harness
IgnitionBLACK/ White Ignition Switch Harness
Ignition 2Blue/Red Ignition Switch Harness
AccessoryBlue / YELLOW Ignition Switch Harness
TachWHITE/ Blue or White ECM Passenger's Kick Panel Pin 10
Brake SwitchGreen Brake Switch
Trunk PinGREEN/ Black (-) Driver's Kick
Parking LightsGREEN / WHITE Front of Fuse Panel 2 Pin Connector
Head LampRED / Blue HL Relay Driver's Fender behind Battery
Hood Pinn/a
Door TriggerGREEN/ Red (-)OR GREEN/ Black Front Fuse Panel 12 Pin Connector Position 8
Door LockBLACK/ Red (-) Rear Fuse Panel 8 Pin Connector Pin 27
Door UnlockBLACK/ Blue (-)
Driver's LockDriver's Side Blue/ Orange (+) Passenger's WHITE/ Black (+) Driver's Kick
Driver's UnlockBlue/Green (+) Driver's Kick
Passenger UnlockBlue/Red (+) Driver's Kick
Horn WireGREEN/ Black 3 Pin Connector Steering Column
Windows UpLF=Red, RF=RED / Blue, LR=RED / White, RR=RED / White
Windows DownLF=Green, RF=BLACK / YELLOW, LR=GREEN / WHITE, RR=GREEN / WHITE
