security compromise methods
johnbauer
Member - Posts: 15
Posted: May 18, 2005 at 2:21 AM / IP Logged
Can you list your top 5 reasons how security systems are defeated?
Being a non-professional, I can see the following ways.
  • gain entry, pop hood, clip siren (30 seconds)
  • gain entry, pop hood, disconnect battery (30 seconds) - go at system at leisure
  • gain entry, find and disable alarm CPU
They range the gamut, from flatbeding the car away, to a professional tow scam.  But, I'm interesting in hardening the most vunerable alarm areas.
Suggestions and anecdotes welcome!
Thanks,
Daz7906
Member - Posts: 22
Posted: May 18, 2005 at 2:36 AM / IP Logged
most system don't have a battery back up, so all you have to do is clip the 12V power wire to the alarm brain. (its the RED one)  so if you are worried about it I would put the brain somewhere other than under the steering wheel, and get your constant power somewhere else as well.
You might what to do an alarm with a two pager so that way you are alerted when your alarm goes off. (as long as you are in range)
TheSaint421
Copper - Posts: 137
Posted: May 18, 2005 at 3:30 AM / IP Logged
I understand what you are trying to accomplish. But keep in mind that all you are doing with an alarm is keeping people honest. there isn't an alarm on the planet that is impossible to bypass, and there isn't a thing in the world that you can do to avoid losing your car to a thief 100%. That being said, Like Daz said, a 2 way pager alarm will alert you when your alarm goes off, or a sensor is triggered. (usually 1/4 mile max) there are glass sensors so even is the thief breaking the window doens't trip the main motion sensor, you have one directly on the window that will set off the alarm if they are broken.
as to making it more difficult if the thief manages to gain entry to the car; well, there are starter interupts, Like connected to the starter, fuel filter, etc. You can have as many of those as you like, or have the time to put in and hide. There should be one wired through the alarm itself, but depending on your needs that might not be enough. Mounting the siren, brain unit and all other alarm related options, (back-up battery etc.) try to mount them in the most pain in the ass places for you to install them, cause if it's a bitch for you to get at it, and you know where it is, it will be that much more difficult for a thief that has to find it. Relocating the hood release cable under the drivers seat or the glove box / console would slow down the thief as he would have to search for the hood release before he could cut the alarm.
Just remember that if the thief wants you car badly enough, he will get it. 10 times out of 10. take care when advertising what you have added to your car, (strereo's video monitors etc.) and park in the best spots wherever possible in lots of light and close to where you will be. Other than that having a horseshoe up your A** would help ;)
regards, The Saint
Pioneer DEH P960MP
Eclipse EQ2102
Focal Utopia 165w3
JL 300/2
JL 10W6v2 (2)
JL Slash 500/1 (2)
Optima Yellowtop
Powermyster
Silver - Posts: 962
Posted: May 18, 2005 at 4:07 AM / IP Logged
depending on the size of the brain, the car and the installer..
A brain Can be fairly tricky to find.. took be bout5 mins to find one in a car that i new very well because the brain was small and he got it into a spot that i wouldn't have ever suspected.   If i had of been breaking into that car and it had one of those mini piezo's even cutting the main siren. would have got me no where until i then found the brain or the second siren.
As the saint sait be careful where you park because if you park you car in the a***ole of nowhere   where people can't hear you sirens a thief can have enough time to get what he wants be it you car or stereo.
Thiefs hate attention thats what alams do draw attention..   and immobilise the vehicle..
mainly its the attention factor that provides you with security
johnbauer
Member - Posts: 15
Posted: May 18, 2005 at 8:57 AM / IP Logged
Very good advice all.  I've somewhat developed a psycological profile of car theives.  "Take their stuff.  DON'T get caught - at least by the owner."  When you park your car, put it with the driver's door facing hour house.  You see a door, they see an escape route.  The street side is easy.  You're 10 paces ahead of him even if he catches you red-handed.  If you're under 30 and in good shape, you've got better than even odds even in the worst scenario.
I will concede that a their can "physically" get an car where no monitoring is possible.  But, unless they're very, very good with cars, I can't see a their having my car start (the hypothetical one with all the layered security items - not the car I'm currently doing - wife's) with it's own starter and run.
When you do a "damn good install", how confident are you that you're safer than 99.9% of the cars out there?  On your personal vehicles, do you do additional things?
Powermyster
Silver - Posts: 962
Posted: May 18, 2005 at 10:36 AM / IP Logged
There are two kinds of thief..
1)  wants to take you car go joyriding, rob a back or whatever..  if you have a decen't alarm. they will as soon got for a car 100 yards up the road that doesn't have an alarm..
2)  This is the dangerous kind. becuase he wants your car. More than likely becuase its a top marque or because you've got a €10000 Audio Visual install..
The 2nd kind is an educated theif more than likely and will go to no end to get your car all you can do is draw attention and make it as hard as possible
Daz7906
Member - Posts: 22
Posted: May 18, 2005 at 10:59 AM / IP Logged
Just remeber one thing...... If a thief wants it they are going to get it.  just do as much as you can to protect your stuff.
thepencil
Gold - Posts: 1,526
Posted: May 18, 2005 at 3:42 PM / IP Logged
Car thief hates attention, if you make the alarm draw lots of attention. It would have done it's job. The more attention it draws and longer it can do it the better.
Be careful whose advice you buy, but be patient with those who supply it.security compromise methods -- posted image.
auex
Platinum - Posts: 5,041
Posted: May 18, 2005 at 4:22 PM / IP Logged
I will go ahead and edit these to correct times using 2 people.
  • gain entry, pop hood, clip siren (5 seconds)
  • gain entry, pop hood, disconnect battery (5 seconds) - go at system at leisure
  • gain entry, find and disable alarm CPU (wouldn't bother because the other options
There are other ideas, but I am not going to go into them due to the fact that I don't want to give any idiots any better ideas then they already have.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
johnbauer
Member - Posts: 15
Posted: May 18, 2005 at 6:07 PM / IP Logged
So a system without a battery backup is pretty much a waste?
Friday, October 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
