791xv remote w/ letter P
wblakes
Copper - Posts: 202
Posted: May 27, 2005 at 12:06 AM / IP Logged
there is a black round button on the back of the remote with a letter "P" what is that button for? i've installed couple of that unit before but none of them have that button on the back. i checked the manual but it doesn't say anything about about. anyone knows???
kgerry
Platinum - Posts: 3,455
Posted: May 27, 2005 at 10:07 AM / IP Logged
the new remotes now have a programming button on the back... this can also be used to select vehicle A or Vehicle B if the remote is learned to more than one vehicle.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
johninaustin
Member - Posts: 8
Posted: May 27, 2005 at 2:09 PM / IP Logged
yeah, if it's the blue viper remote with lcd, on the back, there is a P button, that's for programming....it screwed me up a few times....i accidently hit it with something in my pocket and it changed vehicle on me....keep an eye out for that...if it goes to vehicle 2, 3 or 4, hit it once.....
the owners manual should cover some of what it does (backlight on/off, vibrate on/off, sound on/off)
http://www.viper.com/guides/manuals/og/viper/G564V_01-05.pdf
profuse007
Gold - Posts: 2,015
Posted: May 27, 2005 at 10:49 PM / IP Logged
so viper 791xv start to carry those viper 5000 LCD remote now?
the viper 5000 LCD has some great features and more channels.
Houston,TX
johninaustin
Member - Posts: 8
Posted: May 28, 2005 at 1:33 AM / IP Logged
I'm not sure if they're necessarily compatible, although from the specs, they should be...the only difference between the 791xv and 5000 is that the 791xv has remote start and a couple of other related features, and the remote doesn't have a panic button, it has a start/turbo start button, which is a star....the 5000 has the panic button in it's place.....also, the 791xv has the vehicle shown in a vertical format on the lcd, the 5000 is horizontal.....  The dealer couldn't get a 791xv remote to work with my 5000, so they were gonna swap the brain out...too bad they gave up or i'd have a better alarm...LOL.....not sure if it wouldn't work because they're idiots..or because it just simply can't...
profuse007
Gold - Posts: 2,015
Posted: May 28, 2005 at 2:10 AM / IP Logged
ic ic, the only reason i ask is because of the title of the thread. it seesm arkward to fit but i guess not.
did ur installer use the superstereodyne(however you spell it) antenna, too?
Houston,TX
knucklehead
Member - Posts: 46
Posted: May 29, 2005 at 5:41 PM / IP Logged
Are these remotes backward compatible with the older 791xv's?
KarTuneMan
Platinum - Posts: 7,056
Posted: May 29, 2005 at 5:53 PM / IP Logged
A button on the BACK of the remote? What are they thinking
kgerry
Posted: May 30, 2005 at 9:48 AM / IP Logged
no  ... these new units are AM and the old true Responder units were FM.....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
gus1
Gold - Posts: 1,013
Posted: May 30, 2005 at 10:13 AM / IP Logged
Interesting...... I've all DEI has been sending me for warranty replacement remotes lately have been the new ones with the "p" button on the back. They program just fine to last year's units.....
Gus
