Ai606 in Pug 306
Riviera2k
Posted: May 28, 2005 at 1:23 PM / IP Logged
Ive installed a Ai606 in my 2000 Pug, i havenet fit the immobilisers yet though as i have a good one already on there.
But when i lock the car it beeps 3 time which indicates something in the manual it says Doors (-) what does this mean i increased the pulse to 4secs so that the car locked the deadlocks.
Also the car doors do not lock when the ignition is started does anyone have any ideas, and i cant press the button on the fob to lock the doors either, but the doors lock when i arm with the fob.
Really confused would be greatful for any help.
Ian
Riviera2k
Posted: June 03, 2005 at 6:38 AM / IP Logged
AnY iDeAs PlEaSe
Powermyster
Silver - Posts: 962
Posted: June 03, 2005 at 7:33 AM / IP Logged
are the alarm outputs negative. did you test the lock and unlick wires to make sure thew where negative switches
Riviera2k
Posted: June 03, 2005 at 7:52 AM / IP Logged
Yeah i tested the doors, they lock and unlock correctly when i use the alarm remote, it alarms and sounds when tested.
This is why im confused.
nam-eci
Member - Posts: 25
Posted: June 03, 2005 at 8:16 AM / IP Logged
Bonnet Pin? !
Powermyster
Silver - Posts: 962
Posted: June 03, 2005 at 8:39 AM / IP Logged
yes ckeck your triggers
joe_1
Silver - Posts: 286
Posted: June 03, 2005 at 10:29 AM / IP Logged
i have fitted two of these alarms havent had any problems like that check all trigger inputs and wire the immob wires the correct way, also you might have to program the ignition locking but it should be on default settings.
Riviera2k
Posted: June 06, 2005 at 8:45 AM / IP Logged
I have checked the bonnet switch, and door switchs they all work fine, some one has told me i could be down to the int light delay causing it not to arm correctly.
Also i havent wired up my immboliser circuits yet, so they shouldnt make any difference.
joe_1
Silver - Posts: 286
Posted: June 06, 2005 at 12:43 PM / IP Logged
i will go through the wiring diagram and check it out see if there is any thing that could have been missed out
Evolution-UK
Copper - Posts: 192
Posted: June 19, 2005 at 2:21 PM / IP Logged
3 chirps means that the door trigger is still active on arming. this is usually caused by an interior light delay. software switch 3-6 should be changed to take this into account.
Some cars wont allow the locks to be activated when the ignition is active. This can sometimes be overcome by rewiring the locking system in the drivers door but generally it is easier just to write the feature off.
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
