Don't get ScyTek products ie Galaxy Alarm
xenon2000
Member - Posts: 25
Posted: June 01, 2005 at 4:21 PM / IP Logged
Maybe some of ScyTek products are good, but even then, why buy from a terrible company that won't return emails or phone calls.
I have the Galaxy 5000RS installed, not the 5100. Anyways. I have now had the alarm installed for about a month. And I don't like it. The range is just the worst I have ever had, completely useless for remote start away from home.
And the alarm is inconsistent. I set it for RPM sensing. 1 because RPM sensing claims to be the most reliable way to start the car, yet in this mode it almost never starts on the first try. 2, I wanted it to lock the doors based on RPMs so it doesn't lock right away since passengers often don't have the doors shut before it locks which means the door unlocks when it shuts because as an import is has lame "hold the door handle up" to keep them manually locked. Import owners will know what I am talking about. Anyways, it's not consistent for the door locking, it should only lock based on RPM. But instead sometimes it locks right away as if in the ignition lock mode, sometimes it does it based on RPM and sometimes it does both which is annoying to have it double lock like that.
Also, with the remote start, if it doesn't start the first try it takes forever between cycles. I think about 30 secs between cycles. Doesn't sound like a long time, but trust me, sit there for 30sec waiting for it to try again is forever. My other remote start retrys in about 5 sec and it didn't even have RPM sensing. Seems if it's using RPM sensing it should try cranking for at least 6-10 secs before giving up and then it should be able to see it's not started and retry within 5 secs not 30 sec.
$70 is cheap, but upset because for just $20 more I could have gotten the same alarm I was used to, and from a company that actually replies to emails and phone calls. Scytek in California will not reply to my emails and never calls me back on the phone.
Pro:
  CHEAP and does work, but see the CONs.
Cons:
  COMPANY IS UNPROFESSIONAL, won't call back or reply to emails, not once even.
  Terrible remote range (like 50 feet on a good day)
  Remote is slow to react (feel like I have to constantly press buttons)
  Remote start is unreliable and has no config options other than RPM sensing or Auto.
  Remote start cycle times are way too way apart.
  RPM sensing mode gives buggy door locking results
So don't buy this alarm. I wish Someone else had mentioned these things, I would have stayed clear. At least it's just my GEO and was only $70 shipped.  $90 plus shipping for either of the 2 alarms at 12voltshop.com (Canada) is a much better deal. They reply quickly, are very friendly and helpful. Their alarms are at least configurable, like crank times, etc. And most of all, their products are not buggy like ScyTek. And they are a great company with great prices.
Another note, even my ScyTek Galaxy 5000RS box that said 2003 on it, looked old as if sitting on a shelf since 2003. Avoid ScyTek.
Powermyster
Silver - Posts: 962
Posted: June 01, 2005 at 4:31 PM / IP Logged
i've done the 5100 without any problems. i odn't buy off scytek direct the guy i buy off is fairly helpful
Powermyster
Silver - Posts: 962
Posted: June 01, 2005 at 4:36 PM / IP Logged
just noticed that you got it off X10.com a guy that had a problem with a scytek astra 777 last week bought it off them too. Coinsidance Maybe? I dunno
Alarmtek
Member - Posts: 17
Posted: June 01, 2005 at 4:45 PM / IP Logged
I sell and install they're products and it seemsas if you may have gotten a bad one. Can'ttell without inspection.
Did you get it from Scytek, or from a distributor?Alot of knock offs are out there.
My experience with them has not been the same as yours.I don't work for the Scytek company, but I do theseunits in my shop daily with very little trouble.
The support comes from the dealer you bought it from.If they are reputable, they should sort out theproblems, and or replace the system under warranty.
In any case, I have not seen this bad ofa review on they're systems. I would welcomesome more imput on your installataion to seeif it's a simple fix. I would start by repositioning the antenna .
Regards,
ALARMTEK
Robert Martin/Owner
ALARMTEK ONLINE
www.ALARMTEKONLINE.com
Powermyster
Silver - Posts: 962
Posted: June 01, 2005 at 4:51 PM / IP Logged
https://www.the12volt.com/installbay/forum_posts.asp?tid=55356&KW=X10%2Ecom
this is the thread from shrinktube4.0 who had the problem
xenon2000
Member - Posts: 25
Posted: June 01, 2005 at 4:59 PM / IP Logged
X10.com is a good company, crappy website though. They deal directly with Intel as well. My brother works in the marketing department of Intel and has connections with X10.com and smarthouse.com as well. Anyways. X10.com I can contact. But the alarm is installed so I have to deal with ScyTek and they won't reply to my emails or return my phone calls. If it's just a bad unit, then I wouldn't mind shipping back the box only and swapping it with another one to try out.
All my connections are soldered and heat shrinked. Fully tested with a multimeter. Wiring double checked and tested before even plugging in the box. Wiring is perfect. I programmed the box for RPM sensing and that mode seems buggy. But even then. The range is the worst I have even seen and the remote starting logic is poorly designed. RPM sensing should at least crank much longer than 3 secs before giving up when it senses that the RPMs are not indicating a started engine.
I don't mind the retailers of ScyTek, but ScyTek themselves will not reply or return my phone calls. I have even tried emailing from different addresses in case they have some spam filter blocking them. But they should at least return my phone calls.
But I wanted to let people know my experience as a first time anonymous shopper of ScyTek products. My experience with the company directly has been worthless so far. And the 5000RS works, but is no where near a great alarm.
And even if the box is defective (even though it still works, just poorly) I don't see how the range would improve with a new box. My antenna is in my windshield like my other car. My other alarm gets 1000+ feet easily, so far that you have to listen carefully for the siren tones. This Galaxy 5000RS only gets about 50 feet. And the cycle times probably won't change with a new box either. So lame 30 sec between tries.
So if people (shops) are having good luck with thier retailers (suppliers) that is great. But as a normal person, I don't want something from a company that won't return my emails and phone calls.
Shrinktube4.0
Member - Posts: 49
Posted: June 01, 2005 at 6:46 PM / IP Logged
I know how you feel
ScyTek does have a terrible reputation ignoring their customers mainly when you email them, I myself lost count, and so I finally gave up. I called them on my dime [long distance call] they where a lot more helpful.
Other than that don’t hold your breath. As for their alarms I really have seconds thoughts of how reliable some of them are.
I guessing they are having so many alarm problems questions that they can’t keep up with the volume of problems of emails. I bought the 777 astra it was all working the range on it was awesome except the unlock/lock problem constant positive + in the one wire. Was it a lemon, I think there was a problem with these that where scattered around in different area’s, do you think they will come out and say that there was a product problem on their Model[s]..we all would hope so…I’ve haven’t heard any thing of the sort.
Where is my ALARM [RMA] x10? Did some one say x10.com, they are so-so company at first I had a problem with them when I emailed them for a tracking number they said they would have on for me, but they ignored the heck out of me when emailed them, then I kept calling them and telling them I don’t like to be treated like that and I wanted a refund then they where more cool with me and took care of any problems I had.
OhioMike1101
Silver - Posts: 343
Posted: June 01, 2005 at 7:38 PM / IP Logged
You should be contacting the place you bought the equipment from for a new unit, not scytek.  I do not believe they deal with the general public for warranty or installation issues very often..  Instead of emailing them, try calling them.  I have never had a problem calling them.  And the range issue, I have never had one.  It usually has great range.
I have installed about 75 Astra 777 and 50 5000RS+  I have only had to send 1 brain back in 125+ of their alarms.  I have had to send back about 7 of the 2way pagers though because customers break them.  I have never had a problem with them at all.
We quit carrying them because we had problem getting product during remote start season.
xenon2000
Member - Posts: 25
Posted: June 02, 2005 at 1:23 PM / IP Logged
Well, I will try contacting X10, but somehow I doubt they will exchange just the brain since there is no way I am unsoldering and redoing all my wiring. I have already tried calling ScyTek in California and all I get is a secratary of some kind, she takes a message and I never get a call back.  Normally I would contact the retailer I buy from. I guess it is possible that I have a lemon brain. But seems odd that everything works, just poorly. Only buggy thing seems to be the door locking that sometimes does RPM locking, ignition locking or both. Even though my range sucks, I don't think a lemon brain would cause that. And I doubt that swapping will help my range or the 30 sec long delay between start cycles.
I am happy that others have been having good luck. But I must say that my personal experience with ScyTek directly has been a very poor one. And that alone is enough for me not to buy thier products. I will go back to using 12voltshop.com products. :)
Thanks again for posting your experiences with ScyTek and/or their products you have used.
xenon2000
Member - Posts: 25
Posted: June 02, 2005 at 1:47 PM / IP Logged
OMG!!!! I finally found another number that is for Tech Support, and on my dime I just spoke to one of the most stupid people on the planet.
First of all, I could barely understand this guy.
He laughed at me when I told me I thought my unit was defective and claimed that if it was, it would be the first one in over 7 years. Which I highly doubt.
So I proceeded to tell him my issue about the door locking and RPM sensing and he tried telling me that it's working exactly how it should be working. And started saying that RPM door locking would happen sooner if I programmed the RPM idle with my foot on the gas so the idle would be programmed at 900-1000rpm!!! What an idiot! And he kept cutting me off, claiming that everything I said was exactly how it's suppose to work, etc. And if that is true, then this alarm really sucks because it should not work the way it does. If this was an early generation remote start alarm it would be expected, but this is nothing new and should be refined like many other products are.
I couldn't talk to him anymore and it just proves my point that this company sucks. Regardless of how much product success people claim to be having. I just can't support a company like this or thier products. I hope those who have already bought from them continue to have acceptable working units and hope that people looking to make new purchases will take company quality into account.
I don't know if my venting is obvious, but I have never had such a poor experience with any other car product/alarm company. So much for trying to branch out and try different suppliers. What a joke of a company.
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
