Install Tips: 99.5 VW GTI
ddang
Posted: November 21, 2002 at 12:08 AM / IP Logged
Just wondering if anyone has installed an Alpine SEC-150R or aftermarket alarm on a 99.5 VW GTI (New Body Style)?  Anything to look out for?  Any tips you may have?
Thanks!
Platinum - Posts: 12,488
Posted: November 22, 2002 at 12:36 AM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red                 |+  |ignition harness            |
|          STARTER|RED / gray            |+  |ignition harness            |
|         IGNITION|black               |+  |ignition harness            |
|        ACCESSORY|BLACK/ red           |+  |ignition harness            |
|       POWER LOCK|yellow/blue         |-  |drivers door module *1      |
|     POWER UNLOCK|GREEN/ red *2        |-  |drivers door module *1      |
|       LOCK MOTOR|purple / YELLOW       |   |drivers door module *1      |
|     UNLOCK MOTOR|blue / YELLOW         |   |drivers door module *1      |
|    DISARM DEFEAT|pur/yel or blu/yel  |   |passengers door module *3   |
| PARKING LIGHTS +|gry/red & gry/blk   |   |drivers kick panel          |
|       HEADLIGHTS|yellow/red          |+  |headlight switch            |
|     DOOR TRIGGER|blue/gray *4        |-  |comfort module *5           |
| DOME SUPERVISION|blue/gray           |-  |comfort module *5           |
|  TRUNK/HATCH PIN|brn/blk or brn/blu  |-  |hatch light                 |
|         HOOD PIN|BROWN / red           |-  |comfort module *5           |
|TRNK/HTCH RELEASE|BROWN / black         |-  |comfort module *5           |
|  FCTRY ALARM ARM|arms w/ lock        |   |                            |
|FCTRY ALRM DISARM|disarms w/ unlock   |   |                            |
|       TACHOMETER|*6                  |   |ignition coil               |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|RED / black           |+  |drivers kick panel          |
|     HORN TRIGGER|BLACK / YELLOW        |+  |comfort module *5           |
|           WIPERS|grn/yel and green   |+  |wiper motor                 |
|  LF WINDOW UP/DN|*7                  |   |                            |
|  RF WINDOW UP/DN|*7                  |   |                            |
| SUN RF OPN/CLOSE|*7                  |   |                            |
Notes:NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. *1 The drivers door module is located in the drivers door. *2 A double pulse will unlock all doors and disarm the factory alarm. *3 The passengers door module is located in the passengers door. *4 This wire will read the dome light delay. The avoid the dome light delay, use the separate door trigger wires and diode isolate each one. They are BROWN / white and are all located in their own door at their own door module. *5 The comfort module is the main control module located under the drivers side of the dash. *6 The 4 cylinder tach wire is green with a stripe. The 6 cylinder tach is either purple with a stripe, or black with a stripe. *7 The windows can be rolled up and the sunroof closed by extending the door lock pulse. DEI recommends that you only use a validity channel to roll up the windows.
ddang
Posted: November 26, 2002 at 2:41 AM / IP Logged
Thanks Jeff!
One question, is it possible to use the EXT3 output to roll up the windows?  The output is (-) 200mA, continous or 1 sec. output.  How would I make it stop after the windows are finished closing?
Danny
bluescreen1
Member - Posts: 15
Posted: December 01, 2002 at 6:50 PM / IP Logged
The output of the alarm is fine but you would have to wait by the car and hold the button on the remote(continous mode) until the windows rolled up.  I have done pre 99 vw gti's, 2000 jettas and all i have done was  hook up a "pulse timer relay" to the door lock wire to "extend"  the  pulse.
Ruben
Innovative Sounds
Phila., Pa.
Monday, January 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
