Re: land rover Discovery 1995
Powermyster
Silver - Posts: 962
Posted: June 09, 2005 at 9:04 AM / IP Logged
A friend of mine is going to try an alarm on one of these. I tried looking up the locking System.  DEI Says that its Type F( i'm not sure what  this means).
seen a post on the site here and it mentioned a single wire system another post said that you have to add an actuator. Can someone help me out and let me know how the system works in these. I've heard they are Tricky to work with.
mo12v
Posted: June 09, 2005 at 9:23 AM / IP Logged
That Be...........Single wire system..........Page 8
http://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1041.pdf
MO
Powermyster
Silver - Posts: 962
Posted: June 09, 2005 at 9:31 AM / IP Logged
Thanks Mo
Much appreciated
Powermyster
Silver - Posts: 962
Posted: June 09, 2005 at 10:31 AM / IP Logged
I'm now asked about the factory alarm apparently this vehicle has one.
On the DEI Sheet its gives Disarm as BLUE (-)   Says that it works the same as the Doors
 Whats way does this work. I know that his jeep alarm arms and disarms when he puts the key in the Drivers Door and lock and unlocks
kgerry
Platinum - Posts: 3,455
Posted: June 09, 2005 at 4:15 PM / IP Logged
i sent you a .pdf  email on this.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Powermyster
Silver - Posts: 962
Posted: June 10, 2005 at 5:27 AM / IP Logged
Thanks K for the Mail
