crazy door trigger
yamathegreat
Member - Posts: 13
Posted: June 16, 2005 at 3:58 AM / IP Logged
ok so i have a 93 ford explorer and i taped into the door trigger wire (BLACK/ Light Blue in kick) and it gives me a - reading when the doors are closed and dead when they are open is this odd?
thepencil
Gold - Posts: 1,526
Posted: June 16, 2005 at 9:00 AM / IP Logged
RE: door trigger
Be careful whose advice you buy, but be patient with those who supply it.crazy door trigger -- posted image.
bak0707
Member - Posts: 38
Posted: June 16, 2005 at 7:17 PM / IP Logged
it can depending on what type of trigger the door has. it may be pos. or neg.
sparkie
Platinum - Posts: 2,061
Posted: June 16, 2005 at 9:49 PM / IP Logged
Your truck uses the BLACK/ light blue as it's doorpin wire. It is a positive trigger, not a negative. Most alarms and such have provisions for both positive and negative door trigger inputs.
sparky
Wednesday, February 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
