2004 chevrolet silverado
kannata
Posted: June 17, 2005 at 2:17 PM / IP Logged
need wiring diagram to hook up a command start thanks
thepencil
Gold - Posts: 1,526
Posted: June 17, 2005 at 2:22 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / SILVERADO / 2004 / Remote Start
12volts red (x2)   +   ignition harness
Starter yellow   +   ignition harness
Second Starter N/A
Ignition pink   +   ignition harness
Second Ignition white   +   ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition N/A
Accessory orange   +   ignition harness
Second Accessory brown   +   ignition harness
Keysense lt. green   -   ignition harness
Power Lock use 457G or 456G module
Notes: If Directed module 457G or 456G is not available, refer to DirectFax document 1601.
On base model trucks, the 457G or 456G is not necessary. Instead, the lock wire is lt. blue (-), pin B5, and the unlock wire is white (-), pin B10. They are in the lt. blue plug at the BCM.
Power Unlock see power lock
Lock Motor gray   5wi driver door module in door
Unlock Motor tan   5wi driver door module in door
Parking Lights+ brown   +   driver kick panel
Parking Lights- gray/black   -   BCM, brown plug, pin B2
Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.
Hazards white   -   steering column, 5 pin plug
Turn Signal(L) dk. green   +   steering column, 5 pin plug
Turn Signal(R) lt. green   +   steering column, 5 pin plug
Reverse Light lt. green   +   BCM, black plug, pin F
Door Trigger gray/blk (L), BLACK/ wht (R)   -   each door module in each door
Notes: On base model trucks the door trigger wires are in the lt. blue plug at the BCM, pins B4 and A5. On 4dr trucks the LR door trigger is lt. blue/black, pin A3, and the RR is lt. GREEN/ black, pin A2. They are in the purple plug at the BCM. Use all wires and diode isolate.
Dome Supervision gray/black   +   BCM, black plug, pin E
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm lt. green   -   driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer white   ac   instrument cluster, pin A5 or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the green plug, pin 10.
For tach can also go to any of the ignition coils or injectors and use the wire that is NOT pink, black, or brown.
Wait to start dk. blue   -   instrument cluster, pin A2 or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The wait to start wire is in the green plug, pin 36.
Brake Wire white   +   brake pedal switch
Parking Brake lt. blue   -   BCM, lt. blue plug, pin A7
Horn Trigger BLACK / YELLOW to black   -   steering column
Memory Seat 1 red   +   driver door module in door
Memory Seat 2 pink   +   driver door module in door
Memory Seat 3 N/A   +
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Passlock II
Part #: 555LW
Alternate Part1 #: 555T
Notes: Not required if using the combo interface module.
The Passlock II wire colors are yellow, black, and RED / white (not used).
Door Lock Interface Required:
Yes Type:
Data Bus
Part #: 456G
Combo Interface Required:
Yes Type:
Data Bus
Part #: 457GW
Notes:
Be careful whose advice you buy, but be patient with those who supply it.2004 chevrolet silverado -- posted image.
