530T to control 4 windows one way?
shesaidshewas18
Copper - Posts: 96
Posted: June 17, 2005 at 9:03 PM / IP Logged
Possible or no?
auex
Platinum - Posts: 5,041
Posted: June 17, 2005 at 9:17 PM / IP Logged
Sure, tie the ground when armed and the down triggers together. One set may step but then they will go all the way up.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
shesaidshewas18
Copper - Posts: 96
Posted: June 17, 2005 at 10:34 PM / IP Logged
Whoops forgot to mention that I want all 4 windows to go all the way up. When you say "step" what do you mean? Sorry I dont quite understand that
auex
Posted: June 18, 2005 at 1:00 AM / IP Logged
Well, normally on the down the module will vent the windows and if you keep holding the button then they will go all the way down. In you case two of the windows will go up 2 inches then go the rest of the way up.
Friday, January 30, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
