Remote Start Installation - civic - jetta
jelloboy
Posted: November 25, 2002 at 11:33 AM / IP Logged
I need some assistance.  I ordered two Impulse RES add on remote strt kits for a Honda Civic (2000) and a VW Jetta (2001).
I understand that these are not the best remote starts around, but they were the only ones I found that were "add-on" units.  If you could recommend something else, I can return these.
I need detailed installation instructions for the units AND wiring diagrams for both cars.  The jetta also has some type of passlock system in it that I was told could be bypassed with just a few relays (?).
PLEASE contact me - It's getting cold, and my GF is bothering me to install these systems.
Thanks,
UMS
mobileboy
Member - Posts: 9
Posted: November 25, 2002 at 12:51 PM / IP Logged
The best thing to go with would be a Crimestopper RS 900 but your remote start will work as good if you install it right....  The only thing you have to figure out(assuming you do not have remotes from impluse) is how will you give the units a neg pulse to active the remote start if you do not have a aftermarket alarm.
To do the remote start in the VW you will need a 555 bypass unit.
2000 Honda Civic
WIRE COLOR LOCATION
12 VOLTS CONSTANT WHT IGNITION SWITCH HARNESS
IGNITION 1 BLK/YEL IGNITION SWITCH HARNESS
IGNITION 2 YEL IGNITION SWITCH HARNESS
IGNITION 3  : :
ACCESSORY /HEATER BLOWER 1 YEL IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2  : :
STARTER BLK/WHT (+) IGNITION SWITCH HARNESS
PARKING LIGHTS RED / BLK (+) ABOVE FUSE BOX
DOMELIGHT LT.GRN/RED (-) ALARM PLUG RT OF STEER COLUMN
PWR DOOR LOCK GRN/WHT (-) ABOVE FUSE BOX
PWR DOOR UNLOCK GRN/ORG (-) (TYPE B)
TRUNK RELEASE
TACH SENSOR BLU (-) AT COIL
BRAKE GRN/WHT (+) SWITCH ABOVE BRAKE PEDAL
HORN GRY (-) STEERING COLUMN
FACTORY DISARM  : :
2001 VW Jetta
WIRE COLOR LOCATION
12 VOLTS CONSTANT RED IGNITION SWITCH HARNESS
IGNITION 1 BLK IGNITION SWITCH HARNESS
IGNITION 2 BRN/RED IGNITION SWITCH HARNESS
IGNITION 3 N/A N/A
ACCESSORY /HEATER BLOWER 1 BLK/RED IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2 N/A N/A
STARTER RED / BLU IGNITION SWITCH HARNESS
PARKING LIGHTS GRY/TAN OR GRY/ORG + GRY VIO DIO ISOLATE LF & RT *SEE DIAGRAM*
DOMELIGHT BRN/WHT (-) OR BLU/GRY AT ALARM MODULE
PWR DOOR LOCK YEL/BLU (-) DRIVER DOOR OR RED / BLU DR.KICK
PWR DOOR UNLOCK DK. GRN/RED (-) DR. DOOR OR RED / LT. GRN DR. KICK 2 PULSE TYPE B
TRUNK RELEASE GRY AT SWITCH IN GLOVE BOX
TACH SENSOR GRN/YEL OR GRN/RED FRONT OF MOTOR 2CYL SETTING
BRAKE RED / BLK (+) AT BRAKE SWITCH
HORN N/A N/A
FACTORY DISARM W/LOCKS NEED 2 PULSE TO UNLOCK DOORS *SEE DIAGRAM*
Mike
cpgoose
Gold - Posts: 1,098
Posted: November 25, 2002 at 2:12 PM / IP Logged
HAHARemote Start Installation - civic - jetta -- posted image.
Just for future reference, these companies also make add-on remote starters:
I installed a bulldog remote starter to my girlfriend's existing alarm/keyless entry in her '97 Civic.  The problem I ran into was that once the car was running, she couldn't use her keyless entry to get in the car.  This was cured with 2 relays.  Here's the link for that post if you're interested:  https://www.the12volt.com/installbay/display_topic_threads.asp?ForumID=3&TopicID=2348&Search..
 Just thought you'd like the extra info;)
jelloboy
Posted: November 26, 2002 at 5:48 AM / IP Logged
I looked at the add ons but they don't say how they work.  Do they need a free channel on the remote or can you just push one of the buttons (like the lock button) 3 times and it will start?  Also, do they come with good installation instructions?
I would love it if you could give me more detailed instructions on how to install the 2 relays.  A picture or drawing would be the best thing for me.
Thanks for the response.
UMS
