Can't Find Power Lock
rrspyder
Member - Posts: 26
Posted: November 25, 2002 at 3:48 PM / IP Logged
I want to thank everyone for the help so far and for the wiring charts. Since I received the wire charts I have been trying to locate the wires I will need to tap into in my 2002 Mustang GT. I am, however, having difficulty locating the wires located low in the kick panel, specifically the power door locks. When looking in the kickpanel area I see three major plugs. Two containing 16 pins and the other a 8 pin. These connectors are side by side. I found several lt greens which is one of the colors I am looking for as well as violet.  Is there anyone that can tell me which harness it is at or give me some way to pinpoint these two wires down?
Also, once I tap into these two will this control both the driver and passenger door or will I need to locate additional wires?
Thanks again for the help,
Kyle
securinu
Silver - Posts: 772
Posted: November 25, 2002 at 8:38 PM / IP Logged
the wires are @ the gem module above the driver kick . just above where a foot park brake would be.
rrspyder
Member - Posts: 26
Posted: November 25, 2002 at 9:14 PM / IP Logged
Ok, thanks.. Ill have another look and see what I can see.. SHould I have to remove my dash or anything to see it?
Thanks,
Kyle K
rwl6935
Member - Posts: 15
Posted: November 25, 2002 at 9:16 PM / IP Logged
No Don't remove your dash-
"Keep it simple stupid!"
