Alarm Keyless Entry on 96 Dodge Stratus
therealist
Posted: July 21, 2005 at 11:28 PM / IP Logged
I have the Alarm Fully installed.Only thing Is I cant seem to figure out what I need to do to get it to unlock the Doors.The Locking feature is a go.Just need the unlocking.Thanks for any and all help in Advance.
therealist
Posted: July 22, 2005 at 7:48 AM / IP Logged
This Is A Dodge Stratus
thepencil
Gold - Posts: 1,526
Posted: July 22, 2005 at 8:20 AM / IP Logged
Try using different resistence value.
DODGE, STRATUS, 1996, Power UnLock
Use positive (+) trigger thru a 620 ohm resistor to lock, and a positive (+) trigger thru a 2.7K ohm resistor to unlock. Must use relays.
Here is a relay setup to help you out.
Be careful whose advice you buy, but be patient with those who supply it.Alarm Keyless Entry on 96 Dodge Stratus -- posted image.
