Wiring Diagram for 87 Toyota Corolla FX16
Ae82
Posted: July 31, 2005 at 3:25 PM / IP Logged
Im about to install a car alarm in a 1987 Toyota Corolla FX16. I need information on the wiring diagram and any installation tips. Any help will be appreciated.
mo12v
Posted: July 31, 2005 at 3:57 PM / IP Logged
Constant 12 voltsBLACK/ RED OR WHITEIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK/ ORANGEIGNITION SWITCH HARNESS
StarterBLACK/ WHITEIGNITION SWITCH HARNESS
Dome LightRED / WHITE(-) PASSENGER PIN SWITCH
Trunk Pin Switch
Parking LampGREEN(+) AT FUSE BOX
Power LockBLUE/WHITEDRIVER KICK
Power UnlockBLUE/REDPANEL
Negative Pulse Door Locks
Tach SignalBLACK / YELLOWIGNITION SWITCH HARNESS *
Ignition #2BLACK / YELLOWIGNITION SWITCH HARNESS
Ignition #3
Accessory
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake Light
Reverse LightRED / BLACK (+)AT SWITCH
Rear Window Defrost
* Some Models Carburated.
MO
