2002 BMW 525 Wiiring
colouny
Member - Posts: 31
Posted: August 03, 2005 at 12:47 PM / IP Logged
I'm going to install security system, in this car, so if anyone has some info, please post it. Thank you in advance.
Car Audio and car security systems installer. Best in Car audio.
thepencil
Gold - Posts: 1,526
Posted: August 03, 2005 at 1:09 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - BMW / 5 SERIES / 2002 / Security
12volts red   +   ignition harness
Starter BLACK / YELLOW   +   ignition harness
Ignition green   +   ignition harness
Power Lock blue/red   +   door module in driver door
Power Unlock BLACK/ white   +   door module in driver door
Notes: Unlock requires a double pulse.
Lock Motor
Unlock Motor
Disarm Defeat
Parking Lights+
Parking Lights- black      headlight switch
Notes: Cutting this wire turns on the parking lights. Use a relay to interrupt the wire to flash the parking lights. See DirectFax document 1055 for wiring information.
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger blue/red   +   dome light
Dome Supervision comes on with unlock
Trunk/Hatch Pin BROWN / white   -   trunk pin
Hood Pin
Trunk/Hatch Release gray/black   -   release switch
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer black   ac   round diagnostic plug under hood
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
EWS III
Part #: 556UW
Alternate Part1 #: 555B
Notes: See DirectFax document 1056 for additional wiring information.
Be careful whose advice you buy, but be patient with those who supply it.2002 BMW 525 Wiiring -- posted image.
