2004 Altima unlock
CutDog504
Silver - Posts: 643
Posted: August 04, 2005 at 11:02 AM / IP Logged
Does a 2004 Altima need a double unlock pulse?? If so, how can I obtain a double pulse from an alarm with only a single pulse output??
profuse007
Gold - Posts: 2,015
Posted: August 04, 2005 at 11:13 AM / IP Logged
no dbl pulse, just single.
brown       -       BCM by fuse box, pin 44
Houston,TX
CutDog504
Silver - Posts: 643
Posted: August 04, 2005 at 11:19 AM / IP Logged
Because some wiring diagrams I've seen say that if it has a factory alarm then it is double pulse.
profuse007
Gold - Posts: 2,015
Posted: August 04, 2005 at 12:44 PM / IP Logged
NISSAN, ALTIMA, 2004, Power Unlock
These wires are only available on vehicles with left front only power window anti-pinch system. On vehicles with left AND right front power window anti-pinch system, use the factory alarm arm and disarm wires for door locks.
Houston,TX
CutDog504
Silver - Posts: 643
Posted: August 04, 2005 at 2:24 PM / IP Logged
This is what I found on this site under vehicle wiring off to the left of the screen. Power Lock:
   PINK (-)
PIN # AT BCM NEAR FUSE BOX
Power Unlock:
   BROWN (-)
PIN # AT BCM NEAR FUSE BOX *****
. ***** Unlock Requires Double Pulse. See Note #231. Also See Note #201 Negative Trigger Door Locks.
Is this info wrong?? Because I got a wiring diagram from somewhere else and it says nothing about double pulse or about the power windows that profuse mentioned. Now I'm confused2004 Altima unlock -- posted image.
CutDog504
Silver - Posts: 643
Posted: August 04, 2005 at 2:26 PM / IP Logged
Or is it that a 2004 does NOT require a double pulse but a 2005 does?? Can someone clarify this?
profuse007
Gold - Posts: 2,015
Posted: August 04, 2005 at 3:12 PM / IP Logged
TEST THESE WIRES BY TURNING THE KEY IN DRIVERS DOOR CYLINDER.
let us know the result of ur testing. remember, the diagram given to you are to be tested and not to be plug and chug.
btw, the info was from the directwire by DEI. 05 altima is has a diff diagram.
Houston,TX
Chris Luongo
Platinum - Posts: 3,746
Posted: August 07, 2005 at 12:13 PM / IP Logged
1. It definitely needs a double pulse if it has a factory alarm.
If your alarm does not offer this feature, there are double-pulse generators that are probably still available, but it would have been cheaper to buy the right alarm the first time.
2. If there's no factory alarm, the wires are available right at the BCM, and you test them by operating the rocker switch on the door panel, and you do not need a double pulse.
Wednesday, October 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
